20 Most Recent Beko WM5140W Questions & Answers
The WM5140 is getting to be between 5-7 years old, about the age that the carbon brushes in the motor wear out. You can pick up a new set on Ebay for £6.99 including delivery (take a look at item number 131407433619 on eBay). They are pretty easy to change with the motor in situ, though, personally, I like to drop the motor out and do it on the bench.
Beko WM5140W | Answered on Sep 22, 2015
WM5140W Manual
Beko WM5140W | Uploaded on May 26, 2015
Is your water coming into the washer clean, is the rinse clean water etc. is it your washing powder are you using enough or putting too many clothes at a time in the washer. And, how long has this been doing this?
Beko WM5140W | Answered on Mar 04, 2015
Hi if your beko wm5140w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Beko WM5140W | Answered on Feb 14, 2015
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Beko WM5140W | Answered on Feb 11, 2015
i think the heating element has an issue
i think its a cold water intake only machine
and youve set it too like 40deg wash or 30deg
but if the water doesnt heat up then the machine will be stuck trying to heat water and go no further
its one idea of a few
it could be the preasure switch
this is a job for the repair guy and show him this answer
Beko WM5140W | Answered on Dec 04, 2014
It means there is a fault with it. Put what the error code is and you will get a more specific ansrwer.
Beko WM5140W | Answered on Jul 05, 2014
Beko WM5140W Logo
85 questions posted
Top Beko Washing Machines Experts
Eric Taylor
Marvin
Marvin
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Beko Washing Machines
Most Popular Question
require operating manual beko wm5140w
  • Washing Machines
