20 Most Recent Samsung Galaxy Gio s5660 Questions & Answers
The charge connection is loose. If it is a Micro USB connector, check inside the jack with a strong light and see if the tiny contact board is bent downward. If it is, then it must be carefully bent up a bit. Use a wooden toothpick and insert the point below the contact board to push it up. Then try using a new Micro USB cable and charger.
Samsung Galaxy... | Answered on May 18, 2019
Free codes does not work some times..So better you will get the code from http://www.mobileunlocksolutions.com/ .It helps to unlock your samsung mobile easily.
Samsung Galaxy... | Answered on Dec 28, 2018
Firstly try updating your device, Google Play will likely update with it. navigate: Settings > About > Software Updates and it will check for any updates available for your device (This is based on a newer version of android so it may be slightly different).
If this does not work try navigating to Google Play through your browser. Try this link: Google Play. If your device is hooked up to your Google account you can also install apps through your computer. When there search for "Google Play" in the search box and download it that way.
I hope this helps,
Aaron
Samsung Galaxy... | Answered on Jul 07, 2018
Other solution is to reset (factory reset) your phone. But all your saved files from device will be deleted.
If you're decided to take the loss kindly state your samsung model/series.
Samsung Galaxy... | Answered on Feb 05, 2018
If you lost Samsung data like contacts, photos, messages, videos or other files, you can try Samsung Data Recovery. It can easily recover deleted/lost Photos, Messages, Contacts, Call Logs, WhatsApp, Musics, Videos etc. from All Samsung Devices. It is also capable of previewing data on Samsung freely and selectively before the recovery.
Here are some related articles:
Galaxy S6 Data Recovery - Recover Photos, Contacts, Messages from Galaxy S6/S6 Edge
How to Restore Deleted Pictures, Videos, Files on Samsung Tablets
How to Recover Deleted Photos from Samsung Galaxy S3
How to Recover Data from Samsung Galaxy Note 4/5
The Best Way to Perform Samsung Galaxy S3 Contact Recovery
Samsung Galaxy... | Answered on Dec 15, 2017
Most likely you have WiFi calling enabled, and the local provider SIM doesn't support it. Turn off WiFi calling, and you should stop getting the ER05 message:
1. While you are in Settings, swipe to Network Connections.
2. Hit More networks.
3. Slide the Wi-Fi Calling Switch to OFF mode.
Samsung Galaxy... | Answered on Aug 04, 2015
back up your phone & do hard reset by recovery options,data will be lost
Samsung Galaxy... | Answered on Dec 22, 2014
change touchpad
http://www.samsung.com/ca/support/usefulsoftware/KIES/
( make sure your battery is fully charged )
(1)Do a system Backup with Kies
(2) Go to settings privacy
(3) select the checkbox backup my data & automatic restore
(4) Factory data reset BUT leave format sd card unchecked
(5) Reset Phone
(6) Erase everything
(8) wait for it to restore back to factory settings on your phone
(10) if that didn't work let me know
( GOOD LUCK )
Samsung Galaxy... | Answered on Sep 30, 2014
Press Power Key and Volume Down Key at same time..after some time a menu will be appear then select wipe cache and wipe data.. and reboot ur mobile
Samsung Galaxy... | Answered on Jul 23, 2014
Solution One : Use this app(Its is the Link) to make your problem OK !
Solution Two : Its a server problem!
If the app works out Please do like my page Techno Trust @ fb.com/technotrust
Contacts Sync Fix Android Apps on Google Play
Samsung Galaxy... | Answered on Apr 18, 2014
Hi free unlock code are un trustable many times .I recommend you to visit Onlinegsmunlock.com to unlock your Samsung Gio mobile from network lock .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Samsung Galaxy... | Answered on Feb 08, 2014
use option delete then delete all messages
Samsung Galaxy... | Answered on Dec 21, 2013
I will first take a back up of your Galaxi in the computer and reinstal the oerative system tha cleans every thing. And you telefon will be as new. I use to do with my computer, the iphone of my son and it works all ways. check the handbook of your mobile how to make a system restore first and if it does not help try reinstaling the operative system ( as second option ) that i guess is windows in your Galaxi you find out of it in the handbook or try youtube.god luck!
Samsung Galaxy... | Answered on Nov 13, 2013
unlock
Samsung Galaxy... | Answered on Oct 25, 2013
Samsung Galaxy Gio s5660 Logo
155 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
when try get google play says browser
  • Cell Phones
