GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Ray Anderson http://www.fixya.com/users/moeava has the correct answer. download an app called astro file manager. While Managing your files using this App, you WILL now have an option to delete those bothersome PDF files that have been in your way!
These phones have no memory. Therefore you must shut it down periodically and restart it. It's a pain but must be done in order for it to continue to work properly.
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position. If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
The Sims card is found behind the battery on the commando. Take the battery out and you should see the slot where the card is installed. Hope this helps. ...
Take the battery out. Wait a minute or two and re-install. Now try and power up the phone. This should work, if not you might need to charge the battery or replace the battery.
Yes, you can reboot the phone. Remove the battery for 1 minute and restart phone. My phone does the same issue. It is clashing with one of the APP's that I have downloaded. There are two options. You can remove app's one at a time until you find or you can factory reset your phone
You can send picture and text using email function to an email address.
Usually, with smart phone, you first open the picture. Then, you hold your finger on the picture and there will be a number of functions you can choose. One of them should be email. Choose the email function and continue to fill in the email address you are sending and put in your message in the Subject field. When you finish with them, you can press the Send button to send it out.
Hello. When you know wich films you want to delet, you highlight them and go to options. Then where it says delet, you then click on delet. It will delet the item with no problem. Good Luck.
Hang.. Try doing a factory reset. It depends on the phone type/model. So you got to refer to the manual. If not, and if the support still available, reach Verizon could be your best bet
