20 Most Recent Samsung NP-N145-JP02US NETBOOK Questions & Answers
2answers
How do i add/connect a printer? it doesn't seem to be working for me.
some printers needs its drivers loaded first from the disk,then it will ask you to plug your printer in. if you dont have the disk,then plug printer in and let windows try and find the drivers and what ever updats it needs.
4/6/2015 8:41:44 PM • Samsung... • Answered on Apr 06, 2015
Why My netbook donot show the screen. after it swich on.
Hi Could it be that the light on the screen is turned all the way down? Try to locate the keys on your keyboard and turn the light up. Hope this is the case, it is the least expensive ;-)
2/19/2015 12:16:07 PM • Samsung... • Answered on Feb 19, 2015
Keyboard
Could it be that you keyboard is used and need replacing?
7/11/2013 11:13:21 PM • Samsung... • Answered on Jul 11, 2013
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose. 3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up. 4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.Regards
7/1/2013 10:00:15 AM • Samsung... • Answered on Jul 01, 2013
I dont know how to make the webcam work
Assuming that your laptop diesn't have a built in utility to allow you to view the image generated from the webcam. You could always install Skype or Windows live Messenger (you'll have to sign inn) and you'll be able to check the webcam settings from the tools and options settings of these programmes. :-)
12/24/2012 1:34:40 PM • Samsung... • Answered on Dec 24, 2012
0answers
My Samsung N145 Battery does not power the notebook
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
3/27/2012 9:30:28 AM • Samsung... • Answered on Mar 27, 2012
4answers
I deleted samsung recovery solution 4,from internal hard drive i'd tried to reformat but can't,how an i get the recovery solution 4?
there is 5 step's to reformat you'r Samsung recovery 4 .
A Data Restore reloads files that you have previously backed up using a Data Backup.
To perform a Data Restore, follow these steps:
  1. Tap the F4 Key at the Samsung logo when you first power on the computer. This method would be used if the computer powers on, but Windows does not load.
  2. Click Agree to accept the Licensing Agreement. Samsung Recovery Solution 4 loads. If you close the Licensing Agreement dialog Samsung Recovery Solution 4 will close without making any changes.
  3. Once Samsung Recovery Solution 4 loads, click Restore. The Restore dialog appears.
  4. Click Data Restore. The Restore > Data Restore dialog appears.
  5. On Restore > Data Restore dialog, there is a list of backups created using Data Backup. If no backups have been created, the list will be empty. Select the backup you would like to use for this restore, and uncheck any items you do not want to restore. When you are finished, click Next.
  6. Samsung Recovery Solution 4 displays a window offering two choices. After making a selection, click Next .
  7. Samsung Recovery Solution 4 prompts you to confirm the restore. Click Yes to continue.
  8. Samsung Recovery Solution 4 displays a progress bar to show you the current progress of the restore.
  9. After the Data Restore is complete, Samsung Recovery Solution 4 prompts you to click OK.
    • Click OK to complete the restore.
    • Click Detail >> for detailed information on any data restore errors.
    1. After you've clicked OK, the Data restore is complete. Close Samsung Recovery Solution 4.
2/23/2016 7:38:49 AM • Samsung N... • Answered on Feb 23, 2016
0answers
2answers
VGA CONNECTION TO A SAMSUNG TV NO SIGNAL
have you tryed re,tuneing your tv to see if it finds your vga cable. or try going into your av menu on your tv and it should give you a list of ext1 or ext2 and so on.or try hdmi 1.hdmi 2,and so on.
4/9/2015 10:22:41 PM • Samsung N... • Answered on Apr 09, 2015
Pv420 bios pasword
avoid be misunderstood, read this about ... http://www.wikihow.com/Clear-BIOS-Password
4/6/2015 8:31:31 PM • Samsung N... • Answered on Apr 06, 2015
2answers
I need the manual for my NP900X30 laptop
see the samsung support website for a full pdf copy of your manual
3/30/2015 8:06:37 PM • Samsung N... • Answered on Mar 30, 2015
Instructions delete
Go to control panel on the start menu and go to the program and feature option click tom open it right click on the program to uninstall ,click on unstill to open the uninstall wizard andfollow the wizard to finish
2/3/2015 9:15:13 AM • Samsung N... • Answered on Feb 03, 2015
Power on problem
remove batery and try again
12/8/2014 12:05:52 PM • Samsung N... • Answered on Dec 08, 2014
Samsung NP-N145-JP02US NETBOOK Logo
12 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
N Samsung
  • N Samsung
Most Popular Question
add connect printer doesnt seem working
  • Computers & Internet
