20 Most Recent
Luxor 19822 COB Questions & Answers
My tv is stuck on standby how do i get it off standby
Try a hard reset first. If it do not help you, check and replace its main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
No power in my tv
You may have checked the fuse at the plug...is the socket OK itself? Plug something else into the socket..to make sure it's working...If your not technically minded...don't open up the back of the TV set, but there may be a fuse there also on the main board.. RISK OF SHOCK.
My tv will no switch on
Can I suggest ....if you have not already done so.....Switch off from the power button. Switch off from wall socket. Leave for a few minutes. Plug in..switch on....Make sure if you have a remote the batteries are OK..renew if you need to.
How do i manually turn off the dvd
You might have pressed the AV selector botton on the side panel of the TV. It works as a toggle type switch. Press on once will select the TV input, and for an other press will come back to AV and so on.
Locate that switch you have pressed earlier, and press it once more, to select the input to TV.
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
