ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Hi Angela, The link below is a short youtube video link on how to rest the pattern code on your phone, The guy shows 3 ways but the 3rd way is a factory reset meaning you loose every thing in your phone. I believe the 2nd way will help you...CHEERS..
EASY WAYS How To Unlock Android Passwords
if you just need temp access and you can log into the google account associated with phone. Then you can: (With phone on) go to play.google.com from a pc. log in. and search for lock screen bypass. select your device and choose install. give it a few minutes to complete. reboot phone and wait for a bit and you will see the screen lock bypass app show up. click add admin account. sometimes it will throw you back to lock. just reboot and do it again. once you are at screen lock bypass app after adding admin account press BACK (pressing home will usually result in lock screen). And when you first boot phone its good to wait at least 2 - 3 minutes before pressing back to home screen. (I see better result and less lockscreen hiccups.) once you are finished you can reboot phone again and when bypass pops up you can uninstall from there. While in backup your data and do a factory data reset afterwords to get back into your phone properly.
Hi Doris. The link below is a short youtube video on how to rest the pattern code/pin on your phone, The guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. Also there's videos down the right side that may help as well. I hope this helps...... CHEERS..
Hi Murd, to get out of offline, you have to be online. That means you need to connect to a form of internet. This could be as simple as turning on your wifi on your device. Once your wifi is on, you need to connect to a router. A list usually shows up when you turn on your wifi. Choose your internet router connection, make sure it shows its connected, then try again to see if your still considered offline.
Basically you have probably accidentally swept it off your screen into the trash can all you have to do is go in to your play store or whatever app store you have and redownload your messenger basically it could have happened in your pocket or anything honey just try that.
Depending on your coverage, cell provider, and network it is being sent to, it might take a little while for the message to go through.You can try a reboot.
