20 Most Recent Samsung Galaxy Prevail Questions & Answers
2answers
I have samsung galaxy and how to put there my sim card?sorry for disturbing but i can't find place where i can put it ... please help me quickly !
I have a Samsung Stratosphere, and mine goes under the battery. Not familiar with your phone, but both Samsung so it's possible yours goes under the battery as well.
1/4/2019 1:31:04 AM • Samsung Galaxy... • Answered on Jan 04, 2019
How do i retrieve my deleted messages on my samsung prevail phone?
To retrieve deleted messages on your Samsung mobile phone, my suggestion is
Coolmuster Lab.Fone for Android
. After connecting Samsung mobile phone to computer via usb cable, start the
. A short time scanning later, you can easily get the deleted messages back. https://www.coolmuster.com/android/recover-text-messages-from-samsung.html
12/12/2018 8:46:57 PM • Samsung Galaxy... • Answered on Dec 12, 2018
Colrs changed on my screen
you must have set it wrong, back to settings play around with it
2/3/2018 8:23:29 AM • Samsung Galaxy... • Answered on Feb 03, 2018
Cannot connect to internet via wifi
try to turn airplane mode on and off and try it again or change the date on your phone to the current one
4/20/2017 9:50:54 PM • Samsung Galaxy... • Answered on Apr 20, 2017
Mobile network state says disconnected
Sounds like your phone service has been disconnected. Call your service provider.
7/22/2015 7:42:40 PM • Samsung Galaxy... • Answered on Jul 22, 2015
2answers
I have a samsung galaxy prevail any im tryin to take swype off how would I do it
Gp to playstore and download a different keyboard. Go to setting and set the nrw keyboard as the default
1/8/2015 8:44:14 AM • Samsung Galaxy... • Answered on Jan 08, 2015
Phone keeps flashing internet has stopped on my samsung prevail how do i fix it
Bring the notification window up, up the top you will see WiFi , sound, when you come across Mobile data make sure it is turned on.
8/21/2014 1:18:58 AM • Samsung Galaxy... • Answered on Aug 21, 2014
Samsung galaxy hangs up after two hours
Have gort your battery status checked?
7/28/2014 12:12:09 AM • Samsung Galaxy... • Answered on Jul 28, 2014
WANT TO DELETE PHOTOS ON AUTO BACKUP
Go to the Pictures - Mark those to delete. In Settings choose "delete". That's it. To remove auto back-up you are to disable it (System - Application - choose auto backup - Forced Stop; Disable)
7/28/2014 12:11:11 AM • Samsung Galaxy... • Answered on Jul 28, 2014
Phone has a message to reboot
So just do it!
7/27/2014 11:57:36 PM • Samsung Galaxy... • Answered on Jul 27, 2014
Boot up stuck on samsung
try this Let's start with the most common Hard Reset methods and go from there: Note: the different types of methods are numbered, method 1, method 2, method 3, etc. 1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it. 2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection. 3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key. Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time. If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it. Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it. 4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key). From the Android Recovery screen, press the Search key. Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select. Select Yes - delete all user data, and then select OK (again lower left). Select "reboot system now" and press OK. 5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc. With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time. When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key. Continue holding the Volume up and Home key until the "Android system recovery" screen appears. Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection. Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean. 6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS... While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step). A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key. Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up. Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK. After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK. Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen. 7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS. Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit. The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode. Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up. Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection. After it's done make sure "reboot system now" is highlighted and then tap the Power button. In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through. 8. Here is a hard reset for a Sharp Android Smartphone. While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously. Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection. Scroll down to Yes - delete all user data and then press the Power key to confirm. Once it is done select reboot system now and press the Power key to confirm and reboot your handset. ^_^
7/4/2014 9:36:22 AM • Samsung Galaxy... • Answered on Jul 04, 2014
Samsung prevail hangs up after two hours
7/4/2014 9:17:03 AM • Samsung Galaxy... • Answered on Jul 04, 2014
Phone comes on but my screen stays black
The LCD is bad. Depending on the phone can be a expensive fix. If you need further help, I’m available over the phone at https://www.6ya.com/expert/vincent_b45a16d93e2343f1
6/18/2014 8:07:10 PM • Samsung Galaxy... • Answered on Jun 18, 2014
My phone power button
Depending on the phone the power button needs to be replaced.It's possible that the power button can be re-adjusted.The spring is crooked or fell out of place. If you need further help, I’m available over the phone at https://www.6ya.com/expert/vincent_b45a16d93e2343f1
6/18/2014 8:05:34 PM • Samsung Galaxy... • Answered on Jun 18, 2014
Cell Phones Logo
156 questions posted
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
boot up stuck samsung
  • Cell Phones
