20 Most Recent
ZTE Warp Questions & Answers
Why won't my ZTE phone play music when using an aux cord in my car?
How are you hooking it up? If you are using a USB cord from the phone to the car, most cars cant see the phone as a music device you have to set the phone as a usb storage device and even doing that wont guarantee that the stereo can find the music.
10/14/2016 11:02:35 PM •
ZTE Warp
Answered
on Oct 14, 2016
I cant get in y phone. all it says is launcher stopped working. what can I do
Reboot. Remove battery and wait for 5 seconds. Put it back on. Enter 'Recovery Mode'. There will be some hardware button combination to enter Recovery Mode like Power+Volume Up+Volume Down. After entering, depending on your phone, you might have to navigate through physical buttons.
You will find 'Clear Cache' and 'Clear Dalvik Cache'. Do both.
And then Reboot normally. Now see if you can get the launcher working on your phone.
If that doesn't work, press home key, see if you can open some browser application or Play Store and download and install a new Launcher.
If that doesn't work, but you can somehow access settings, go to settings->Apps and clear data of your Launcher App.
If that isn't possible then, go to Recover Mode again and do 'Reset Factory Defaults'. This should make your phone feel just like when you brought it.
5/19/2016 12:28:13 PM •
ZTE Warp
Answered
on May 19, 2016
How to unlock
If your phone is pattern locked then either it will ask for Gmail account details if you have registered one or you can just enter *983*987# in the Emergency Dial which unlock your phone and also your phone will be resetted and all the datas will be erased. If your phone is locked with some PUK code then contact your service provider to unlock the phone.
8/18/2015 7:08:51 AM •
ZTE Warp
Answered
on Aug 18, 2015
How can i unlock my android after too many pattern attempts
phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
8/5/2015 4:15:47 AM •
ZTE Warp
Answered
on Aug 05, 2015
Charging port to phone
It sounds like the charging port is warn out. If you have a warranty on take to the store. If not, well to my knowledge there is no way of replacing it. Best. there a warranty. Worst. You need a New phone.
6/10/2015 7:39:44 AM •
ZTE Warp
Answered
on Jun 10, 2015
