20 Most Recent
Huawei M835 Ideos Questions & Answers
Reset password
Please help me out i forgot my pattern and they are asking me to sign in
and i have forgot my emailaddress and password please help
Reset not working
GO ON YOUTUBE AND THERE IS A VIDEO I HAVE FOUND THAT RUNS THROUGH THE PROCESS, HOPE THIS HELPS
How do I unlock the phone after too many failed pattern attempts
Here's the reset instruction for huawei m835- Press Send Key
- Press Volume Up
- Press Power button hold all three keys at the same time until a black screen with yellow lines appear
- press Wipe Data
- Then Reboot
you will need to start everything over again. recreate gmail and password.( write it down this time)download all your apps again..enjoy!!!
Huawei M835 low storage notification
From http://www.hard-reset.com/nokia-n70-hard-reset.htmlNokia N70 hard reset
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.If it is not working try this code:You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.Some Nokia phone can be reset via this menu optionPress menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
I set a pattern to unlock. I forgot the pattern
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
