20 Most Recent
Sony Tablet S Questions & Answers
Forgot my password for my sony s tablet
Hello Let me clarify you question. When you say forgot password do you mean that you put a protective password to sign into your tablet and that is the one you forgot? If so there is no way to get back in without it unless you do a factory data reset on your device.. This will erase everything including your personal data unless you have backed it up somewhere and any apps that you have personally placed on the device as well but you can get those back as long as you use the same google account.
Before doing anything if you have a sd card in side you want to take that out or everything that you have on that card will be erased as well.
1.Press and hold the volume up button and then the power button until you see a black screen with blue lettering
2. To get to factory reset use your volume up and down button
3 Use the power button to select it.
4.Then you are going to want to do the same thing again to get to reset tablet
5.Using the volume up or down to get to Reset Tablet and then use the power button to select it.
6.You will be prompted asking you if your sure you want to reset the tablet just click on Erase Everything. Your tablet will begin the resetting process
7. When your tablet comes back up it will be up at the activation screen ie the setup process.
Hope this helps.
How do I reset a Sony Xpedia SGPT1211 tablet?
To do a hard reset on the xperia tablet, first power it down.
Then, press and hold "Volume +" for roughly 3 seconds. While still holding "Volume +", then press and hold Power for an additional second.
Use "volume -" to arrow down to the factory reset option. Press power to select this option.
Then on the next screen use "volume -" again to navigate to the YES option to confirm this is what you wish to do (NB. all data will be erased).
