20 Most Recent
1999 Peugeot 206 Questions & Answers
Peugeot 206 thermostat housing torque settings
@Kenneth Ella: In my Peugeot 206 1.4 (TU engine series), tightening the thermostat housing bolts with a torque 20 nm was the breaking of the thread in the engine head. I think, correct torque is about 10 nm (8-12 nm).
206 peugeot total distance recorder not working
In this model, the gearbox should be fitted with speed sensor, as it provides the info of vehicle speed to the instrument panel(dashboard) by means of speedometer and the total distance covered. So, does the speedometer work proberly, does the needle move correctly? If yes, you have to change the instrument panel. if the answer is no, then the speed sensor is not working, either the sensor itself or one of its wires is broken. Notice that this sensor is a hall-effect type, which means that there are 3 pins on the sensor , 1st is 12V supply, 2nd is 0V (earth) 3rd is a signal wire that transfers signal to the points I mentioned above.
goooooood luuuuuuuuuuuck
