20 Most Recent Coldtech 21 cu. ft. / 595 liter Commercial Freezer J2SFF-21B Questions & Answers
2answers
Commercial freezer stops cooling and goes into delay start mode.
unfortunatly the company has gon out of buisnees and parts availableare kind of hit and miss. As a profesional technician it really frustrating.I would definitly look at the control side of it. some it could be the relay or digital controller. Good luck hunting the parts down. There are some online parts dealers that still carry some parts. Have your model numberand serial number readily available when ordering.
11/15/2014 9:11:14 PM • Coldtech 21 cu.... • Answered on Nov 15, 2014
My freezer has a a
sounds like it may be overcharged. The popping sound is actually liquid refrigerant coming back to the compressor. Has it been worked on recently? If it has trefrigerant will have to be removed.
4/18/2013 1:12:58 AM • Coldtech 21 cu.... • Answered on Apr 18, 2013
0answers
Completely dead
let's start with the basics. Are you sure you are getting the correct power to the unit? If 120 volts, use meter and check across power and neutral, not power and ground. If correct power is present, check the defrost timeclock for proper operation. If bad and stuck in the defrost cycle, nothing will work except for the defrost heaters. It should terminate defrost cycle and return to the freeze cycle, but if terminator is bad, it will just sit in defrost. Start here and get back to me and we can continue.
10/16/2010 10:38:25 AM • Coldtech 21 cu.... • Answered on Oct 16, 2010
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
10/24/2009 12:58:54 AM • Coldtech 21 cu.... • Answered on Oct 24, 2009
Evaporator freezes up
No model # .. Im assumeing its frost free.. so that means a defost problem.. heaters, defrost themostate or timmer.
9/2/2007 11:32:45 PM • Coldtech 21 cu.... • Answered on Sep 02, 2007
Looking for a set of keys for Coldtech Commercial Freezer model J4SRF-40B it has GEM lock assembly
question edited for clarity. Question moved from Misc. 50 years in the trade and never heard of that make. Normally you just replace the whole lock or the lock cylinder.
Lock & Key Children Fridge Safety Lock - GEM HOME
gemhomeaccesories.com https://gemhomeaccesories.com > products > lock-key... Lock & key Children fridge safety lock -1595/-. Package Includes: 2 Keys. 1 pcs Black Fridge Lock. 1 Installation Sheet. 2 Extra Adhesive Pads. Parts, although a local locksmith could supply a lock body and keys. https://www.google.com/search?q=Coldtech++J4SRF-40B+replacement+lock ..
2/1/2024 4:53:01 AM • Coldtech... • Answered on Feb 01, 2024
Coldtech SF-104 Controller blew out. Looking for answers as to the cause
probably a short in the element or in the compressor
7/11/2019 3:44:57 AM • Coldtech... • Answered on Jul 11, 2019
0answers
0answers
J1gf-20s/j2gf-40s
Be the first to answer 10/29/2013 4:04:30 AM • Coldtech... • Posted on Oct 29, 2013Be the first to answer
Rollers for refrigerator unit doors
you find that freezer shop it best if you fixed from shop where you freeze bought.
3/26/2013 5:06:02 AM • Coldtech... • Answered on Mar 26, 2013
I need to replace gaskets
The model number which you gave is not proper.But the nearest model number is J3GF-61S.In your model number its J36F but actual model number is J3GF. You will have to order the part from coldtech service center :--- Contacting ColdtechPhone: (800) 314-4477
Mail:
Jimex Corporation
1575 Zephyr Avenue
Hayward, CA 94544
USA.--------------
The online link providing this parts is as follows.Click the link:-- http://www.tmeinc.biz/xcold.htm ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
9/9/2010 5:36:30 PM • Coldtech... • Answered on Sep 09, 2010
I would need a service manual, location to
http://www.ascendmfg.com/index.html
Go to this website. It is for Coldtech refrigeration. I could not find your numbers but you can contact them for information thru this site. Good Luck and hope this helps.
8/16/2009 2:24:35 AM • Coldtech... • Answered on Aug 16, 2009
Freezer with loose red and blue cables
All question need full 'make model (what it is)', first 3 words. Google make model wiring diagram. Brown or Red is normally power and blue is return. https://www.google.com/search?q=Freezer+with+loose+red+and+blue+cables ..
4/22/2024 11:19:39 PM • Freezers • Answered 2 days ago
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Coldtech 21 cu. ft. / 595 liter Commercial Freezer J2SFF-21B Logo
9 questions posted
Top Coldtech Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
View Most Popular
Coldtech Freezers
  • Coldtech Freezers
Most Popular Question
commercial freezer stops cooling goes
  • Freezers
