20 Most Recent
ROOTS MAI TAI Ry2142BLK Watch Questions & Answers
How to change the battery for leather roots watch
Razor blade to pop open the back. Remove the battery. Replace. Snap the back into place. This is easy if you arent worried about a watch that isn't worth much and didn't cost much. Don't get suckered into these services and click bait.
How to set alarm on oots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now. Now press and release the start/stop button (top right) and the minutes will flash, again for hours. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. To turn the alarm and/or the hourly chime on or off, hold in the adjust button (top left) and press the start/stop (top right). Each time you press the start/stop (top right) the CH or AL or both symbols. When the symbol is showing, that function is on.
How do I change the time on my Roots tiki watch?
Press Mode until the time/date screen shows on watch face. Hold Set for a second or two and quickly press Mode. The Hour should begin flashing, meaning you can now adjust it. Press the Adj button repeatedly to scroll through each hour and once it is correct, press Mode again to move onto next item. You can adjust Hour, then Minutes, Month, Date, Day of the week, and Seconds. If you wait too long you'll have to start again at Set and go through each item by pressing Mode. Press Set after you've adjusted the final item you want, or stop pressing buttons and the reset will eventually time out and flashing will stop.
