20 Most Recent
D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b) Questions & Answers
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624.
Note: If you do not remember your password, you will have to reset the router to factory defaults.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing).
VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password.
Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
How to install DI 624
The router can be installed without the CD. If you are experiencing any problems, you
can reset the router to factory default settings, press the reset
button at the back of the router.
Please
note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE
LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you
get the connectivity, however, you have to make the connection secure
etc.
Reset the router to
factory default setting, press and hold the
reset button for few seconds (It is at the back of the router near the
DC Power Jack). The LEDs will then blink and the routers factory
settings would be restored.
Please note that, after resetting the router you should be able to see
the router and connect to it via LAN Cable or Wirelessly as the router
automatic assigns the IP Address and gateway etc. Before proceeding to
the next step please make sure that you are getting the signals as well
as internet. However, the internet connection would not be secure, which
can be done later.
Now, all
you have to do is connect to the router and secure
the connection follow the following steps: -
First
you have to access the router through web browser (Internet Explorer)
by typing the IP address of your router in the address bar, which is
192.168.0.1 (Default router settings are written under the router) (unless
you've configured otherwise, the default username is admin and
the password "leave it blank") and
lookup for the options to do the
following: -
1. Change the SSID (Name) of the router
2. Change
the default administrative user name and password
(The above step
would prevent unauthorized access to your router)
Next step is to
secure it:
1.On the left-hand side, under Setup, click "Wireless
Setup"
2.Under "Wireless Security Mode", select your desired encryption method
(preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as
long as it's 8-63 characters in length
4. Click Save Settings.
Now
your router and your connection would become secure and the user has to
provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Lost software
This is NO software as such as it is all built into the router, simply access router properties by typing the router address (192.168.0.1) into the browser.
When I did restart then i want use d-link it says
When you reset a router, it restore its settings to factory-default. If you are attempting to log in to the router's control panel, you will now have to use the factory default login credentials.
These credentials are:
Login: admin
Password: admin
Let me know if I can assist you further, or if I need to explain any of what I mentioned above in more detail.
If you found my solution to be helpful, or if it resolves your issue, please rate the solution.
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
How do I upgrade the firmware on my VDI-604 or VDI-624?
Step 1 Download the latest firmware.
Click here to download the latest firmware for the VDI-604 - http://support.dlink.com/products/view.asp?productid=VDI-604#firm
Click here to download the latest firmware for the VDI-624 - http://support.dlink.com/products/view.asp?productid=VDI-624#firm
Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter.
Step 3 The default username and password is listed below for your version of firmware:
Click OK.
Step 4 Click on the Tools tab at the top and then click Firmware on the left side.
Step 5 Click Browse and navigate to the .bin file you downloaded in Step 1. Select the file and then click Open.
Step 6 Click Apply. It may take a up to 30 seconds for the firmware upgrade to complete.
Step 7 When prompted click Continue. The firmware upgrade is now completed.
Step 8 If you get a Page cannot be displayed or similar error after clicking Continue, close the web browser and re-open it. Repeat Step 2 to login to the web-based configuration.
Freedom
try this link:
http://www.freedom.net/support/bug.html
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
How do I open a range of ports on my VDI-604 or VDI-624 using firewall rules?
Step 1 You will need the IP address of the computer that you want to open ports to.
How do I find the IP address of my computer?
Click OK.
Step 4 Click the Advanced tab at the top and then click Firewall on the left.
Step 5 Select Enabled and configure the following:
Name - Enter a name to identify the rule
Action - Select Allow
Source Interface - Select WAN
Source IP Range Start - Enter an IP address or * to allow this rule to apply to all incoming IP addresses. If you are opening this rule to a series of IP addresses, enter the first IP address in the range.
Source IP Range End - If you are opening this rule to a series of IP addresses, enter the last IP address in the range.
Destination Interface - Select LAN
Destination IP Range Start - Enter the IP address that you obtained in Step 1
Protocol - Select the protocol (TCP, UDP, or Both)
Port Range - Enter the starting and ending ports that you want to open
Schedule - Select Always to apply this rule all the time or Schedule to specify a schedule
Step 6 Click Apply and then click Continue to apply the new rule.
Parental control
The following types of parental control can be configured on the VDI-604/VDI-624:
Domain Blocking
URL Blocking
Domain Blocking
Domain Blocking will allow/deny access to certain websites.
Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username and password is listed below for your version of firmware:
Click OK.
Step 3 Click the Advanced tab at the top and then click Parental Control on the left.
Step 4 Below Parental Filters, select Domain Blocking.
Step 5 Below Domain Blocking, select Allow users to access all domains except "Blocked Domains" to only allow to all websites except those listed or select Deny users to access all domains except "Permitted Domains" to only allow access to the websites listed.
Step 6 Enter the website (i.e. disney.com) below the option you selected in Step 5 and then click Apply.
URL Blocking
URL Blocking will prohibit access to websites than contain certain words.
Click OK.
Step 4 Below Parental Filters, select URL Blocking.
Step 5 Below URL Blocking, select Enabled, enter the word, and then click Apply.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
