20 Most Recent
Samsung LN46B610 46 HDTVReady LCD TV Questions & Answers
TV was hit with a lightning surge; won't turn on.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Samsung lcd tv with double image on screen
T'Con board should be suspected.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1300 posts to different brand TVs now. Pull up
older posts there.
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Increase brightness in samsung tv
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Why dont i have a picture?
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
