20 Most Recent
Nokia 5233 Cell Phone Questions & Answers
I forgot passlock password in nokia 5233
Hello My Dear:::::"::defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Sim rejected
Is rejecting the card because your phone is locked to another carrier, you need to unlock it in order to use it.
Why my Bluetooth is not working in nokia5233
You must activate the bluetooth from the settings. Then only will it work. Make it visible in the BT settings. Same thing on the other device as well. And they both will see each other. Connect with a password.
Nokia 5233 water dameg dade
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Unlock key
Contact your network provider
to get the unlock key for your Nokia 5233. If they failed to provide, you can get it from online
providers. You should pay for the code to get that. Get the code from
the site
Theunlockspot.com
here you should also provide network provider to which your mobile is
locked, country to which the locked network belongs to and IMEI number
of your mobile. Unlock it by yourself using simple step by step
unlocking instructions which is given in the site itself.
