20 Most Recent
Toshiba Camileo P10 Flash Media Camcorder Questions & Answers
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased
mine second hand so it came with no charger. I assumed it would charge
by the USB cable but it did not, the red light flashes but doesn't
charge. Luckily I have an external battery charger for a different
camera i got some years ago that takes a similar battery , the P10
battery didn't fit properly so I had to place it at a 45 degree angle
into the charger making sure the outer contacts were lined up properly
and taped it into place. After an hour it was fully charged and the
camera is working fine. The charger is a 4.2 volt charger. New external
chargers can be picked up on ebay cheaply
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased
mine second hand so it came with no charger just a USB cable. I assumed it would charge
Does anyone have low volume during playback on the toshiba camileo x100?
you can make the audio louder. see about raising the volume and then when playback make sure it's not too loud. If that doesn't work then the cameras is set low in the audio. see manufacturer if they have a solution. or in the camera see if there is a volume control, maybe it's set low.
How to set time and date
1. In setting submenu, press UP/Down Button to select Time Setting. 2. Press Menu/OK Button to go to the Time Setting menu.3. Move between date and time by using Up/Down Buttons. Adjust date and time by using Left/Right Buttons.4. Press OK Button to validate the setting. Or Press RECORD/PLAY button to leave Time Setting without any change.
Why does My Toshiba TY-CKM39 eats tapes ?
The idle tire for your VCR is either dirty or has worn out and has stopped the tape reel from being able to move and turn and also the rubber parts need to be replaced or cleaned as ell.
Toshiba Camileo h20 battery problem
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
