20 Most Recent
D-Link DWL-520 Wireless PCI Wi-Fi Compatible LAN Card(Refurbished) (RDWL520) Questions & Answers
I installed a Belkin broadcast
Go to my computer control panel network connections and see if the setup for networking is correct DHCP should work most of the time. Check the device manager and see if your nic is properly recognized. If not you might need to install drivers for the card.
mycomputer - control panel
mycomputer - view system information - hardware - device manager
Also, sign onto your router and see if the router recognizes the computer.
It should tell you how to do this in the routers manual.
I need to install D-Link
ftp://ftp.dlink.co.uk/wireless/dwl-520/dwl520_driver_july_2002_9xmew2kxp.exe
there is the link for your drivers
Please leave feedback if this has helped you
Device will not start code 10 message
Code 10 means DRIVERS COULD NOT BE INSTALLED. Try installing the drivers manually.
Do this if pc is XP.
1.Keep the wireless adapter connected to the pc
2:Go to control panel, add/remove programs. Remove the wireless adapter software
3:Restart the computer, when the found new hardware wizard shows up click on it, click NO NOT THIS TIME, then select install from a list of specific location. On the next page Click on DON'T SEARCH, I WILL CHOOSE THE DRIVERS TO INSTALL.
4.HIGHLIGHT NETWORK ADAPTERS on the hardware type, the CLICK HAVE DISC
5.Click BROWSE to set the location of your drivers
6.Open the driver folder, then the pc should copy the files.
Good Luck
ADD 4% boost to your Wireless Network
This is simple and easy. to do grab your wireless adapter. and grab 90cm of very thin copper wire. now wrap the copper wire around your adapter and bang you should have At Lease 4% boost on your Wireless. some people say they got 8% boost but i only get extra 4%
Good luck Enjoy
Drivers
We encourage you to use Tips and Tricks as a starting point for sharing
your technical knowledge and know-how with other FixYa users.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
