20 Most Recent
Creative Labs PC-Cam 300 Digital Camera Questions & Answers
Process Cropping
Most digital cameras have an aspect ratio of 4x3.
35mm cameras have an aspect ratio of 3x2.
6x4 photopaper also has an aspect ratio of 3x2.
Therefore you don't get cropping when printing from 35mm film.
To make the picture fill out the 6 inches, the digital footprint has to be 6" by 4.5".
So .5 inches is removed in the process.
If you can find a processor that will print 5.333 x 4 on the 6 x 4 paper, there would be no clipping necessary.
Since you have Photoshop, you can crop the photo to a 3 x 2 ratio. That way you control what is cut.
I use Photoshop Elements and when I use the Rectangular Marquee Tool, I set Style to "Fixed Aspect Ratio" and Width to 3, and Height to 2.
Outdoor picture is all white
I found the same problem. I was able to solve it by adjusting settings as follows:
Go into 'Camera Settings' - top right blue button in video view.
You need the 'Camera Setup' tab.
Click 'Source' button.
Click 'Advanced Settings' tab.
'Banding filter' - check 'Outdoor'.
'OK' your way out.
Problems with a driver for PCCAM-300
That driver is compatible with WindowsXP. What is the error you're getting? If it's related to Windows logo testing, then you can just choose "Continue anyway", and install the drivers.
Lost my PC-CAM 300 software
PC-CAM Center application is only available on the installation CD. If you have lost it, then check with support if they have the CD available.
PC-Cam 300 no longer functions as a digital camera
Let's do a hardware reset on the player:
Press Snapshot button and Operational mode button simultaneously for more than two seconds this will delete all the files from the camera. A beep sound is heard when the memory is cleared and LCD displays zero.
This may get the camera working again.
PC Cam 300 and PC Cam 600
Probably the driver isn't installed properly. Try updating the driver for PC-CAM 300 and PC-CAM 600.
Cant download music
This is a camera site.If your player is a MP3 player then - MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
DIGITAL SOLUTIONS PC DIGITAL CAMERA/DRIVER
see the steps : God bless youIf the camera won't connect with your computer, make sure you have the
latest version of the needed software drivers (in your digital camera
package or online from the manufacturer). Check your computer for
conflicts (two devices trying to use the same port); you may need
technical assistance for this one. In some cases you can get things
working again by connecting the digital camera, then turning off the
computer and turning it back on.
