20 Most Recent Samsung HM1000 Bluetooth Headset Questions & Answers
2answers
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device 2.press& hold call answer button in bluetooth device now light is on ,not blinking 3.and then search your bluetooth device by your phone and pair.
8/27/2022 10:06:02 AM • Samsung HM1000... • Answered on Aug 27, 2022
0answers
0answers
Not Working
Be the first to answer 2/24/2014 3:13:20 AM • Samsung HM1000... • Posted on Feb 24, 2014Be the first to answer
MY LG TONE HBS-730 stuck on incorrect pin i have samsung mobile
Here are some steps you can try: Reset the Headset: Turn off the headset. Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple. The headset will reset, and you can try pairing it again. Pairing with Samsung Mobile: Make sure your Samsung mobile's Bluetooth is turned on. Slide the power switch on the LG HBS-730 to the "ON" position. The LED indicator on the headset will be solid blue, indicating it's in pairing mode. On your Samsung mobile, go to the Bluetooth settings and search for new devices. Select "LG HBS-730" from the list of devices. If prompted for a passcode, enter "0000" (four zeros). Once paired, you'll hear "Your headset paired." Check Battery Level: Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low). Charge the Headset: Connect the charger to the headset. While charging, the LED indicator will show a solid red light. When charging is complete, the LED indicator will turn off. Remember that the headset will automatically turn off if not paired within 3 minutes. If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
4/20/2024 10:44:15 PM • Samsung Radio... • Answered 3 days ago
Remote control for my vr headset will not sync up with my samsung ace phone
Both volumes buttons should be press at the same time and check out all settings before starting a https://mybestvrheadset.com/how-to-make-a-vr-headset-without-lenses
5/5/2021 7:05:05 PM • Samsung Radio... • Answered on May 05, 2021
2answers
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
11/18/2019 10:42:38 AM • Samsung Radio... • Answered on Nov 18, 2019
How to program a Samsung tv remote AK59-00149A
https://www.manualslib.com/download/436713/Samsung-Bd-F5100.html From above link down load manual and see instructions on page 13 of this manual, it will solve your problrm.
5/13/2019 7:46:09 AM • Samsung Radio... • Answered on May 13, 2019
Samsung giga Bluetooth stuck in waiting mode
Try disable bluetooth and switch off for 5 mins and then back on and enable bluetooth.
10/5/2018 8:08:33 PM • Samsung Radio... • Answered on Oct 05, 2018
How do you charge a Samsung wep500 without the Cradle
get another cradle. It cannot be done. CrackBerry com review of Samsung WEP 500
3/30/2018 3:28:48 AM • Samsung Radio... • Answered on Mar 30, 2018
Samsung HM1000 Bluetooth Headset Logo
Popular Tags
16 questions posted
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Radio Communications
Most Popular Question
pair samsung bluetooth headset model
  • Radio Communications
