20 Most Recent
HP ProBook 4530s Notebook Questions & Answers
Unable to access wordpress dashboard on my hp-pc notebook windows 7
WordPress is a free, open source blogging platform. You can install WordPress on your own Web server or you can sign up for a free WordPress blog through the WordPress.com website. The Dashboard is used to access and manage the administration of the blog. From the Dashboard, you can create new posts, edit existing posts, change the blog's theme and add widgets. You can rearrange the Dashboard, and add additional Dashboard modules and widgets to suit your particular needs. Open any Web browser. Type "www.your_site.com/wp-admin" or in the brower address bar, if you installed Wordpress in the site's root directory. Type "www.your_site.com/blog/wp-admin" if you installed Wordpress in a subdirectory. Replace "www.your_site.com" with the URL for your website. Replace "blog" with the subdirectory name. Type your username and password in the appropriate text boxes, and click the "Log In" button. Click on the "Dashboard" link on the left side of the screen, if you are not automatically directed to the Dashboard. b> WordPress.com Open any Web browser. Type "www.your_blog.wordpress.com/wp-admin" in the browser address bar. Replace "your_blog" with the name of your Wordpress blog. Type your username and password in the appropriate text boxes, and click the "Log In" button. You will be directed to the Dashboard automatically.
My computer hp probook 4530s cooling fan not
You'll probably have to replace it. There are videos on youtube that can give you instructions on how to replace it, or you can bring it into a qualified computer repair shop and they can replace it for you.
I have the HDMI cord plugged in to both laptop and TV. Computer will not detect
Try connecting the tv first... Or getting a new wire.
If those don't work you might want to try the monitor button. Most laptops have them as one of the function keys. Often looks like a projector or a square with some extra lines. Try it with the fn key depressed and also without as fn lock might be on.
But try those first two things first.
How do I fix "HP_DATA partition not found. Cannot capture data."
Is the HP Tools Partition still on the drive?
Right click Computer
Left click on Manage
Let Computer Management load
On the left is Disc Management
Click on it and on the right information about your local drives that are installed will load.
Your C drive should show up and it will list all partitions.
Does one of them says HP Tools?
Did this problem start after installing the Office software?
Does the HP Quicklook pop up come up every time you open Outlook?
If so have you gone in to see if its a program that you can uninstall from Add/Remove programs? If you can uninstall it do so.
I found this information when searching for hp quicklook
HP QuickLook is a Personal Information Manager (PIM) viewer for Microsoft Outlook 2003 and 2007. HP QuickLook caches Email, Calendar, Tasks, and Contact Information from Microsoft Outlook 2003 and 2007 and enables users to view and edit this data quickly from a notebook that is Off or in Hibernation mode (without having to open Microsoft Outlook first).
So if you don't need it, uninstall it. It could be causing the issue that you are having.
How if, user profile service failed to log0n
Use the F8 key on power-up, it uses a different administrator login.
You can then proceed to user accounts on control panel and delete and create a new user which should solve the problem.
My laptop fn keys not working...?
hi ali
That key does not work as an "Apple Fn" key -- it is handled internal to the keyboard, so it is not really a "key." (rather, it modifies other keys) to make them generate different codes. But you can make your function keys swap. See SysPrefs -> Keyboard -> "Use all F1, F2..."
