20 Most Recent HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled Questions & Answers
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
HP Officejet 100... | Answered on Sep 11, 2014
Unplug it, leave with no power for 15 mins, power up and update drivers from the net. Also check and replace cartridges if needed.
HP Officejet 100... | Answered on Jul 21, 2014
please check the paper path could be something block the paper
or broken
Hope help you
HP Officejet 100... | Answered on Nov 11, 2013
The bin full black switch on top of printer may be knocked off its mount
HP Office... | Answered 3 hours ago
Code 30.1.8
Scanner optical unit position error.
1/
Check the scanner lock to verify that it is in the unlocked position.
2/ Turn the device off and then turn the device on.
3/ Make sure that the optical unit moves freely and that it is attached to the belt.
4/ Check the scanner motor connector at the scanner control board (connector 10).
5/ If the message persists, replace the scanner.
HP Office... | Answered 15 hours ago
Use the comment menu to provide more information about your question, please.
Example from a search using https://www.google.com but unknown what type of printer or other error conditions you are experiencing.
https://support.hp.com/us-en/document/c01944870
HP Office... | Answered Yesterday
LOL THE PAPER IS WHITE THE LINES WILL BE THE PROBLEM CALLED BANDING SOME TIMES THE PRINT HEAD NEEDS CLEANED
do you get power to the printer? have you checked if there is a paper jam? is the ink/toner finished?
HP Office... | Answered on Dec 01, 2019
I'm not sure if the M402 is affected by this or not, but this could be your solution:
https://cincinnatiprinterrepair.com/m477-with-59-f0
HP Office... | Answered on Nov 29, 2019
Chances are you have a paper jam. Remove the toner and open the back door and check for a paper jam. If you had a paper jam previously and had the paper tear on removal, look for small strips etc.
HP Office... | Answered on Nov 26, 2019
Blue and yellow, or cyan and yellow combine to make green. I suspect that the other colors needed for a particular document are empty, or the wrong colors were placed in some slots. I would be surprised if that printer would accept the wrong ink cartridge in a slot though.
Here are the steps that HP recommends.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00786157&dlc=en&product=3204785
If you make it the Service the product you will want to call HP and get it replaced under warranty.
Hope this helps
HP Office... | Answered on Nov 19, 2019
HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled Logo
5 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
make hp officejet 100 discoverable
  • Office Equipment & Supplies
