20 Most Recent Kettler treadmill Pacer Questions & Answers
I have an error on my treadmill: system fault DC6, how can i fix it without asking for service?
Try to follow this steps if still not working Visit the nearest store where you brought it and claim a warranty if its under warranty.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. ...
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
6/30/2020 4:41:48 PM • Kettler... • Answered on Jun 30, 2020
2answers
E1 ERROR
Does the walking belt move for a brief moment, then immediately stop, followed by the E1 code? Or is there no belt movement at all when start is pressed?
3/22/2019 12:42:35 PM • Kettler... • Answered on Mar 22, 2019
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
4/9/2018 10:11:48 AM • Kettler... • Answered on Apr 09, 2018
I have Kettle pacer treadmill,when I press start button the display shows error DC 6 and belt does not move
have you kept the belt regularly lubricated ? can't find this error code in manual
9/16/2016 2:10:47 PM • Kettler... • Answered on Sep 16, 2016
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
11/26/2014 1:44:34 AM • Kettler... • Answered on Nov 26, 2014
The speed does not corrolate to what i key in and is going much slower than it should
www.kettlerusa.com/fitness/treadmills
7/8/2014 1:41:31 PM • Kettler... • Answered on Jul 08, 2014
Motor won't come on,everything works and motor is good
Check the voltages comes to the motor. http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
6/29/2014 2:59:26 PM • Kettler... • Answered on Jun 29, 2014
0answers
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
4/26/2014 3:44:16 PM • Kettler... • Answered on Apr 26, 2014
0answers
0answers
Error code 7
Be the first to answer 2/8/2014 8:12:39 PM • Kettler... • Posted on Feb 08, 2014Be the first to answer
0answers
Dc6
Be the first to answer 1/15/2014 5:55:29 AM • Kettler... • Posted on Jan 15, 2014Be the first to answer
E1 error after start
this ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs from the speed setting. Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or the signal is not reaching the display. see the diagram attached. God bless you 8aa471e2-eb3e-4152-9565-99282c83168c.gif
11/28/2013 10:40:46 AM • Kettler... • Answered on Nov 28, 2013
0answers
Ater starting the treadmill, it runs at 1mph then
Run the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor and follow the steps.God bless you
10/1/2013 12:42:46 PM • Kettler... • Answered on Oct 01, 2013
Kettler treadmill Pacer Logo
33 questions posted
Top Kettler Exercise & Fitness Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Kettler Exercise & Fitness
Most Popular Question
error treadmill system fault dc6 fix
  • Exercise & Fitness
