20 Most Recent
Reebok treadmill i-run s Questions & Answers
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Smell of burn when in use
1) LUBE THE DECK BELT INMEDIATELY , THIS HAPPEN BECAUSE THE LACK OF MAINTENANCE SCHEDULE SEE YOUR OWNER MANUAL.maybe you have some deck Worn.2) LUBE THE ROLLER BEARING INMEDIATELY, LACK OF MAINTENANCE.God bless you
The running belt has come off my reebok I-run
1) Lube the deck belt inmediately, this happen because the electronic system protect itself, shut down.2) Lube the rollers bearing very well3) MEAsure the voltage input motor, if there are the motor need repair4) Measure the output voltage board, for input voltage motor, if there are not THe board is faulty.see the block diagramGod bless you.
Adjust voltage on motor control board
Dear Sir:You can adjut the voltage motor in m.m.board.The only way is 1) Put some regulator voltage in the line for to maintain the voltage in the line Good 2)Try to get some circuit special for your treadmill without interference 3) You can add the voltage from the transformer inside from your machine.However You can RUN the software calibration for diagnose, troubleshooting, and fix it.sincerely. God bless you
Speed stuck on fast
adjust the speed sensor, clean, and tigh the connector wires.see the diagram2) RUN the software calibratin Inmediately, for diagnose, troubleshooting and fixi it.sincerely. God bless you
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Reddit · r/fixit
3 comments · 4 years ago
Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits
https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ' Show results with:
GT30
Treadmill Support - Reebok Fitness
reebokfitness.info
https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Reebok treadmill e13 error message
f the E13 error code is still showing after restarting your treadmill, check to ensure that the wiring between the AC motor drive and motor cables is securely connected. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.
Reebok 8000ES stuck incline position will not decline.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj79pDHxZSCAxV_AHkGHbhiDxkQFnoECBsQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Ffitness-equipment%2Fgdah0-reebok-8000es-treadmill-incline-keeps-going.html&usg=AOvVaw0mEH-BLg44uwLpy6jJGb3K&opi=89978449
