Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
10 questions posted
191 Questions
96 Questions
39 Questions
34 Questions
36 Questions
