20 Most Recent
Sole Fitness Sole F85 Treadmill Questions & Answers
Sole F85 E2 error code. Have adjusted the sensor
If it was moved . Most likely the cable was damaged where the right upright bar slides into the frame. You will need to take the console off and remove the right upright , too access the cable. Unless you live in NC you could call, wilsons triad fitness 336-313-6253
F85's "low speed" error
Dear Sir:1) Lube the deck belt very well, as your instruction manual indicate for maintenance.2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.sincerely. God bless you
Electronic display in rotation
If youre meaning that the buttons do not function this could be caused by sweat getting inside. Replace electronics inside or entire console.
Fan not working
Your display pcb board needs replacement.....call sole for service
Sole F85 Hand Rail Incline Adjustment Switch is
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
