20 Most Recent
Samsung ML 1750 Laser Printer Questions & Answers
Paper slips and is not
Heya,
What you could do is try and clean your feed/pickup rollers with some Spirits/Surgical Alcohol which will remove the smoothness to them. Just give the rollers a proper cleaning but make sure printer is off. The rollers tend to become smooth after a while but will work fine again after being cleaned. If that doesn't help then i would suggest taking it to a repair shop to have your separation/pickup kit replaced.
Rergards,
Sumsung 1750 printer will not print
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
thanks.
Both lights flashing
No it is not. Both lights point to a bad fuser unit, a part not replaceable by end users.
Check printing on ML 1750
Your check paper might be too thick for the printer. It has been designed to handle paper 20-40lbs. If common paper prints fine, it means that the printer is not able to bring the check paper to the exit tray, where the fuser is located. The fuser is the part that heats and makes the toner print permanent. Try printing your checks through the manual tray.
Samsung ML-2000
from where i can download printer driver for samsung ml-2000 series laser printer
