20 Most Recent
Samsung CLP-550N Laser Printer Questions & Answers
Error Message--Waste Toner Tank Full/Not Install
What I have started to do is to actually wash the toner tank out with water and make sure it is good and dry then be sure the section that breaks the light sensor is good and clean (it is on the left side as you look at the backside - the side that goes toward the printer - and protrudes out) the tank full indication comes on when the tank gets dirty
Label Printing
On the subject of <a href="http://www.selfadhesivelabels.com/label-printing.html">label printing</a>, i actually get all my labels printed by a british labels company for a really low price. If anyone is at all interested then it may be worth taking a look at their website as they do all types of label printing.
Transfer belt error and unlocking
Welcome to Fixya
Check and clean the sensor. There is sensor inside the transfer belt, on the bottom side of the transfer belt (pink side).You have to screw off 2 screws from the plastic cover from the pink side of the transfer belt. When you screw off plastic cover, you will see three wires which is going to sensor. There is 1 screw which hold sensor; you have to screw off that and gently pull out sensor. Sensor looks like letter U, and on the inner side of the sensor there is two small holes on the opposite sides. You have to clean that holes (blowing or with small brush). CLEAN IT WELL. After that, reassembe transfer belt, put it back, turn on printer.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Printer not working
go to the samsung website and under support /downloads and download the driver for windows 7 that corresponds with your printer. unplug your printer and turn it off reboot and then start he install process again. follow the steps. I had to call brother support once to figure it out i had the same problem. Good luck
Where is the reset fuse
A fuse should never be a resettable device on a product. Fuses are made to open if there is an over temperature situation or an over current situation.
Reset is normally controlled by a button sequence on the front panel.
Can you please provide a full description of both the failure and the "Fuse" description for me?
Don
Chged transfer roller still have message won't print
Check first the Reset Fuse. If the fuse has blown, you might get any error message and the printer would not work. Check or replace the fuse to see if that would help.
If the same problem occurs, contact the manufacturer to see if they have the latest firmware version for the printer. It would look like it does not make sense, but it's true. If the firmware is not working correctly, firmware upgrade would make the printer to work better.
Have a great day!
