20 Most Recent Samsung ML 1210 Laser Printer Questions & Answers
Please visit http://www.samsung.com/us/support/search/supportSearchResult.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelaserprinters&subtype_cd=06010400&model_nm=ML-1210&dType=D&vType=&mType=&model_cd=&menu=%2Fsupport%2Fsearch%2FsupportSearchResult.do&prd_ia_cd=06010400&acc_ia_fl=N&disp_nm=ML-1210&isEqualsY=
If you need to search Samsung.com for the printer drivers, type in "ML-1210" under the model number.
Hope this helps!
Samsung ML 1210... | Answered on Jun 28, 2019
hi Dear
Please send me the driver of Samsung ML 1210
Thanks
With best regards Shakeeb
Samsung ML 1210... | Answered on Oct 17, 2018
I have the same problem. did you find the solution???
Samsung ML 1210... | Answered on Aug 22, 2013
The fuser is the last stage of the printing process - it's what "fuses" or basically bakes the toner into the paper. It's a hollow metal tube with a heater element inside it - that element (lamp) has to reach normal temperature or it will give you that error. Could be the lamp itself burned out or could also be an electrical problem in that circuit. Requires a technician to replace the lamp.
Samsung ML 1210... | Answered on Jul 16, 2012
HERE is the manual to set up your printer
Samsung ML 1210... | Answered on May 05, 2012
You may be able to get a printer driver from the Samsung WEB site.
You can download the Samsung printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.samsung.com/au/support/main/supportMain.do
Samsung ML 1210... | Answered on Jul 11, 2011
Please go to this link http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1210.
Scroll down.
Under Products Support please click Universal Print Driver.
Scroll down a bit.
Under Downloads select your operating system.
Hope this helps.
Thanks
Samsung ML 1210... | Answered on Jul 09, 2011
empty the toner waste bin
Samsung ML 1210... | Answered on Jul 03, 2011
to solve your problem you need the USB to Parallel adapter. Find examples here:
http://www.google.hr/#hl=hr&source=hp&q=usb+to+parallel+adapter&oq=usb+to+para&aq=1&aqi=g10&aql=&gs_sm=e&gs_upl=1146l3721l0l11l10l0l3l3l0l240l1191l0.4.3&fp=92b2044ee890eadb&biw=1366&bih=611
Regarding drivers, if you dont find for Win 7 try from XP.
Hope that helps!
Samsung ML 1210... | Answered on May 29, 2011
There is no problem if you have a new cartridge - just open the printer, pull an old cartridge and insert a new one (follow the instructions, provided with new cartridge)
But if you want to refill an old cartridge - you'll need to disassemble it, clean with service vacuum, fill with new toner and reassemble the cartridge. So it requires some skills.
Samsung ML 1210... | Answered on May 19, 2011
Copy the link below and paste it onto the address bar. Download and install it after.
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=2305398&CDCttType=DR&ModelType=C&ModelName=ML-1210&VPath=DR/201011/20101115101918937/Samsung_Universal_Print_Driver.exe
If you're having difficulties, go to http://www.samsung.com/us/support/downloads/ML-1210 and click on the universal printer driver.
Samsung ML 1210... | Answered on Mar 03, 2011
  1. Turn the printer off by pushing the power button in until the LED light turns off. Make sure the printer is off before proceeding.
  2. Remove the power cord from the back of the printer. Leave the printer unplugged for at least five to 10 minutes.
  3. Plug the printer back in. Press and hold the stop button for two to three seconds until the demo page begins to print.
Hope it works...
Samsung ML 1210... | Answered on Mar 01, 2011
Samsung ML 1210 Laser Printer Logo
66 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ML Samsung
  • ML Samsung
Most Popular Question
easy fit new toner
  • Office Equipment & Supplies
