20 Most Recent
Samsung ML 1510 Laser Printer Questions & Answers
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On
The following conditions can cause the On Line LED to glow solid red:
- Printer paper is jammed inside your printer.
- A cover is not be closed properly.
- The toner cartridge is not inserted properly and needs to be reinstalled.
- The toner cartridge is running low.
- There is no paper in the paper tray.
- The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
I recently purchased an iMAC
I have a Mac Mini using Samsung ML-1510 and recently upgraded to Lion. Splix makes it all work: http://guigo.us/mac/splix/
Cannot install ML 1510 printer?
hi, could be an incorrect driver, i guess. if that's the case, getting a right one should work. if you tried samsung site but still no help there, hope this site for printer drivers can help you get a working one easily and correctly instead:
http://tinyurl.com/6x8ky6b
hope this helps you. good luck.
How do I find a free driver for my smsung ML 1500 printer
1st You download Printer Driver.
Samsung Laser Printer Driver
After this install the Printer driver in the system.
Installation of Printer Driver
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Select the Unknown Device or printer device where yellow Question Marks sign on it.
- Right click on it and uninstall it.
- After this go to the top of the device manager and click on scan for hardware changes.
- Driver installation Wizard start.
- Brows Your Driver from the Hard Disk and click on next.
- Driver will be install.
Pages printing with a longitudinal stripe
This is due to toner may get over. Remove the toner catridge and shake the same and reinsert may solve your problem. Also change the toner catridge if required and check.
Revert back for more assistance.
