20 Most Recent
Panasonic HX-WA10 Dual Camera, Full HD MP4 Vertical Camcorder - Black 16MP, 3M Waterproof, 12x Intelligent Zoom, 5X Optical Zoom, EIS, SD Card Recording, Face Recognition 3-inch LCD Questions & Answers
I have a panasonic Lumix camera and it keeps
Hello and Welcome to FixYa!
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
You can see the snap attached below;
If the lock switch is not on lock;
- Slide the switch up and down. Repeat this 3 times.
- Let it stay on the Lock position for 30 seconds.
- Slide the switch up to unlock the card.
- Try to transfer files into the device.
If none of the above works, then you card in either damaged (Format it) or is Password protected.
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
11/28/2023 7:18:52 PM •
Panasonic...
Answered
on Nov 28, 2023
I want to change language from Japanese to English Panasonic CN H500D
To change the language on your Panasonic CN-H500D, press the "Menu" button on the remote control. Use the arrow keys to select the "Setup" option, then press the "Enter" button. Select the "Language" option, then press the "Enter" button. Use the arrow keys to select the language you want to use, then press the "Enter" button. The language will now be changed to the one you selected.
2/21/2023 10:01:11 PM •
Panasonic...
Answered
on Feb 21, 2023
My panasonic vdr150 pc mode not working
It sounds like you are having trouble using your Panasonic VDR-D150 camera in PC mode. Here are a few things you can try to troubleshoot the issue:
Make sure that the camera is properly connected to your computer via the USB cable.
Check that the camera is turned on and in PC mode.
Check that your computer recognizes the camera as a device. You can do this by going to the "Device Manager" in the Control Panel and seeing if the camera is listed under "Imaging devices."
If the camera is not listed in the Device Manager, try unplugging and re-plugging the USB cable and restarting your computer.
If the camera is still not recognized by your computer, try using a different USB cable or a different USB port on your computer.
If none of these steps help, it is possible that there is a problem with the camera itself. In this case, you may need to contact Panasonic for further assistance.
12/24/2022 10:12:47 PM •
Panasonic...
Answered
on Dec 24, 2022
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete.
To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set.
For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again.
For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.)
The manual for DMC-LS80 is available from Panasonic support here:
https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is
https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures.
I hope this helps.
(if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
7/7/2022 6:22:48 PM •
Panasonic...
Answered
on Jul 07, 2022
MOVIE FILE NOT RUN
Your camcorder can only play back movies recorded on that specific device, due to the way the software within the camcorder works.
PS - please don't shout when you post queries
3/14/2022 7:17:40 AM •
Panasonic...
Answered
on Mar 14, 2022
For some reason, my video is a .mov file and when
First of all, you can't rotate a video without some expensive software installed on your computer and even then, the results will be poor at best. Download Quicktime from Apple to play your video...it's a free download.
12/2/2021 7:28:45 PM •
Panasonic...
Answered
on Dec 02, 2021
