20 Most Recent Cisco (1841) Router (cisco1841) Questions & Answers
That is a very good question, but that would take way more space than this forum offers. A good router tutorial, which covers the configuration from the IOS command-line interface can also be found here.
You should check out Cisco's page on EIGRP (link) or Petri's Blog about configuring EIGRP (link), but if routing protocols are in general a new thing for you, you will be better advised to get a book that covers all protocols, otherwise this might not make any sense to you.
Look for this:
CCNA - Cisco Certified Network Associate Study Guide by Todd Lammle, Publisher: Sybex
You can get it at amazon and it costs you only 20$ (used) or 30$ new including shipping. Here is a link.
If you have specific questions, I'm happy to help, but in the book it's already more than 60 pages on IRGP/EIGRP alone, so I don't really want to type that all up, plus you would need some general information as well.
Cisco (1841)... | Answered on Jul 18, 2019
Default admin username, cisco. Default admin password, cisco
Cisco (1841)... | Answered on Oct 13, 2017
change subnet to 255.255.255.0 on every pc connected
Cisco (1841)... | Answered on Mar 27, 2017
I don't really know what your asking but i guess you want to know why your startup-config doesn't load. What your router is displaying is normal. You need to change the configuration register.
1.Let the router load then if asked select Yes to abandon autoinstall, then select No to skip initial setup. Press return (enter button) when asked.
2. Now type the following at the prompts. (you type the bold stuff press enter after each command)
router>enable
router#conf t
router(config)#config-register 0x2102
router(config)#exit
router#reload
........save changes blah blah blah.. type NO
continue with reload Yes
providing you have a startup-config, the router will now load it on bootup.
Hope this helps
Pokeabeaver
Cisco (1841)... | Answered on Jan 10, 2017
Make sure you set up correctly the subnet mask.
Cisco (1841)... | Answered on Dec 28, 2016
This is more of a business unit. It requires a serial port connection and a fair amount of CISCO networking engineering knowledge. It is command only. No GUI interface.
Cisco (1841)... | Answered on Dec 26, 2016
Can you provide more information please. Where are you downloading the image ? From your router to Pc. from Pc to Router ?
Cisco (1841)... | Answered on Aug 06, 2014
Connect a computer with the Router.
Open Command Prompt
Type: ipconfig
Lots of information will be displayed.
Scroll up if required and search for: Ethernet Adapter Local Area Connection:
In that category you will see one listed as Default Gateway.
And that is the IP Address of your Cisco Router.
yes, but it only works for incoming access to the console, not outgoing calls.
Cisco (1841)... | Answered on Jul 31, 2014
Are you using a Cisco Rollover cable. Cisco does not use a standard console cable. They are usually blue and flat.
Cisco (1841)... | Answered on Jun 09, 2014
Try resetting its firmware or try booting it in another location.
There are two things that can cause this:
  1. Incorrect serial settings. The default settings are 9600 baud, stop bits of 1, and parity 0. However, it is possible that these settings were changed. Likely, the baud setting may be higher as someone may have tried to XMODEM an IOS image onto the device and wanted faster speeds.
  2. Bad connection, cable
I hope this answers your question.
With the set command.
Example:
rommon > set
PS1=rommon ! >
IP_ADDRESS=172.18.16.76
IP_SUBNET_MASK=255.255.255.192 DEFAULT_GATEWAY=172.18.16.65
TFTP_SERVER=172.18.16.2
TFTP_FILE=c2600-i-mz.bin
Alternatively you can XMODEM an image on there. However, that takes a long time, even if you increase your baud rate.
Also, on 2800 series routers you can put the image on a USB flash drive. However, the drive must be formatted as FAT and the partition size cannot be larger than 256 MB. This might work for an 1841.
Cisco (1841)... | Answered on Apr 16, 2014
It is not on the network then.
Cisco (1841)... | Answered on Oct 11, 2012
Basically you will need to use TFTP to get the IOS back on. HERE is an article from Cisco that explains how to do it. I have done this before and even though it takes a while to reload the IOS (because in my case I had to use a serial connection at 9600 baud) it does work.
Cisco (1841)... | Answered on Aug 25, 2012
Cisco (1841) Router (cisco1841) Logo
78 questions posted
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cisco Computers & Internet
Most Popular Question
default password linksys before
  • Computers & Internet
