20 Most Recent
Samsung (TN-RBNG10) TV Input Questions & Answers
TV USB Input - Displays mp4 video from laptop?
this is not true..flash drive yes can carry audio/video, but unless there is some sort of media player to read the file while plug to usb...some tv monitor can open (jpeg files) photos (slide show) but not video
6/6/2010 1:23:29 AM •
Samsung...
Answered
on Jun 06, 2010
How to put input on a samsung plasma?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
4/11/2010 5:58:58 AM •
Samsung...
Answered
on Apr 11, 2010
Television inputs keep telling me that i have no signal
Try resetting the signal from the PS3.
Press the power button and hold it until you hear a few beeps in a row.
Power it off again, then back on.
Make sure to have the TV set to the input the PS3 is connected to & turned on before starting the PS3.
Peter
3/26/2010 5:27:06 AM •
Samsung...
Answered
on Mar 26, 2010
The picture blinks three times and then blanks out
This sounds like your monitor back light is not working. If you look really hard at the screen, can you see a very dim picture? If so the back light isn't working. This is almost always an inverter problem and can be fixed.
1/13/2010 3:46:46 PM •
Samsung...
Answered
on Jan 13, 2010
My Samsung TV has no
There are devices that can read SD,Micro SD with RCA jack (YELLOW JACK) that made for TV viewing. Digital picture frame with yellow RCA out out + converter to coax plus. ==== Example eBay Item number:230382583829
SD Card + USB Media Player for TV - Connect to your TV if your are using MicroSD then you will need a MicroSD to SD adapter. It's real cheap. should do the job for you. LINK HERE === Please rate my answer if it's useful to you. Cheers, MUSTGO
12/12/2009 7:48:46 PM •
Samsung...
Answered
on Dec 12, 2009
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
Yesterday
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
