20 Most Recent
Swift M3500 Monocular Student Microscope Questions & Answers
Need a reference manual for swift nine fifty microscope
Swift microscopes, as far as i know, don't readily come with a users manual like one would find for a standard home device. Nine fifties are of the simplest microscopes around, any guide to microscopy will do as a user's manual. As for repairs, anyone that is mechanically inclined and with the right tools (allen hex keys, screwdrivers, pliers, lubricant) will be able to fix one after a few minutes of tinkering with it. Don't panic.
It appears that some water
Unfortunately, if you indeed have water or oil inside the lens it is probably ruined. Obviously the seals have deteriorated away. Objectives are practically irreparable. They cannot be disassembled. Very reasonable new and used Replacements are available at:
Delta Optical Instruments, Inc.
Inquire at:
[email protected]
Need a manual
Go on line to the Manufacturer's web site and request an owner's manuel for your microscope!
Are spare objectives & eye
most objectives and eyepieces are interchangeable between models of microscropes. There are however a few things that you need to be aware of. On the out side of the objective there are number written on them that look similiar to this:
100x/1.25
160/0.17
There maybe more writing then that, but usually at the very least you get this. The first part (100x) is the objective magnification, the 1.25 is the Numerical aperture, the 160 is the tube length (in mm), and the .17 is the cover-slip correctness. What you are most concerned with is the mechanical tube length. There are 3 common ones, 160, 210, and infinity. It is very important that you get an objective with the right tube mechanical tube length, or there is a very good chance it won't work. If you are working with slides, then it is a good idea to get one that is cover slip corrected, otherwise most of the other information is only real important to very specific applications.The other key variable is the threading. Most microscopes use what is call a standard RMS threading, however many educational or high end objectives will not have this.
The eyepieces are pretty straight forward. You just need to find one that that has an outside diameter of the sleeve that will fit the inside diameter of the tube it is going into. Beyond that, most eyepieces are pretty interchangeable amongst brands.
I need a light socket and lamp for a Swift Eleven
Carolina Biological sells swift and carries parts for them. If this is not it, http://www.carolina.com/product/swift+upper+illuminator+lamp+m28hfz10.do?keyword=swift&sortby=bestMatches try calling them up and ask them if they have the part.
AA-Spectrometer Unicam 939 Error
The error you are experiencing on your Unicam 939 AA-Spectrometer with the software reporting error 16 and 2, along with lamps 1,2,3,4, and 10 lighting up, could indicate a few different issues. Here are some steps you can take to try to fix the problem:
- Restart the spectrometer: Turn off the spectrometer and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on again. Sometimes, a simple restart can fix issues with the instrument.
- Check the calibration: It is possible that the instrument needs to be calibrated. Follow the manufacturer's instructions for calibrating the spectrometer.
- Check the lamps: If multiple lamps are lighting up, it could be due to a problem with the lamp assembly. Check that the lamps are properly installed and functioning. Try replacing any lamps that appear damaged or worn.
- Check the power supply: Make sure the power supply is functioning properly by testing the voltage output with a multimeter. If the voltage output is incorrect, try replacing the power supply.
- Check the communication between the software and the spectrometer: Ensure that the software is properly communicating with the spectrometer. Check that the cables are properly connected and that the software settings are correct.
If these steps do not resolve the issue, it may be necessary to contact the manufacturer for additional support or to seek the assistance of a professional repair technician.
3/24/2023 6:39:35 AM •
Science &...
Answered
on Mar 24, 2023
