20 Most Recent Ricoh Aficio CL2000N Laser Printer Questions & Answers
Go to the following link. At least this is where I found the latest driver for Mac OSX 10.5+
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/c30e/c30een.htm
Ricoh Aficio... | Answered on Nov 26, 2019
Development Motor Lock While the motor is operating, the motor lock signal remains LOW for 2 s. Causes. • Motor lock
Ricoh Aficio... | Answered on Apr 17, 2019
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Ricoh Aficio... | Answered on Apr 12, 2019
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
Ricoh Aficio... | Answered on Aug 15, 2015
in the menu of the printer there usually is a TCP IP Printer setting where you can change the IP address.
Ricoh Aficio... | Answered on Jul 25, 2015
Something inside printer is blocked. There is a magnetic clutch that sometimes could be a reason. Check that Waste Toner bottle is not full because in that case many bad things can happened.
I can tell you this for sure:
it's time to replace the printer with new one!!!
Maybe you will be able to buy cheep SPC410, SPC420. They are perfect
Ricoh Aficio... | Answered on Sep 22, 2014
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Ricoh Aficio... | Answered on Sep 17, 2014
Press the yellow reset button, then 107 then you hold the red stop button. The mode clear is usually a 5800-xx-xxx something. Just clear the SCS, dont say clear all!
Ricoh Aficio... | Answered on Jul 23, 2014
If any color is light that will cause that failure
Ricoh Aficio... | Answered on Feb 05, 2014
Ricoh Aficio CL2000N Laser Printer Logo
154 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error message says reset pcu correctly
  • Office Equipment & Supplies
