20 Most Recent Ricoh Aficio 2018D All-In-One Laser Printer Questions & Answers
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Ricoh Aficio... | Answered on Nov 22, 2019
Below is a link to the driver download site for your Ricoh Aficio 2018D Laser Printer. Please note that although these drivers are still available for download, official technical support for this model has been discontinued.
To download the drivers, click the following link:
http://support.ricoh.com/bb/html/dr_ut_e/re/model/x2015_18/x2015_18en.htm
If you found this solution helpful, please leave a positive rating!
Ricoh Aficio... | Answered on Apr 18, 2018
sounds like photo conductor is bad will need to rebuild or replace it
Ricoh Aficio... | Answered on Mar 22, 2017
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
Ricoh Aficio... | Answered on Aug 05, 2016
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Ricoh Aficio... | Answered on Jan 25, 2016
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Ricoh Aficio... | Answered on Jan 19, 2016
You have a broken part:
AA08-0342 is the part number.
It can't be easily replaced. I hope you are skilled enough.
My advise is to find technical person.
Pifonski
Ricoh Aficio... | Answered on Dec 07, 2015
my dear you first side door open after you frand door open and remove drum unit
Ricoh Aficio... | Answered on Sep 02, 2015
what photo check your post it isn't there
Ricoh Aficio... | Answered on Apr 12, 2015
901 B Mechanical total counter
The mechanical total counter does not
work properly.
• Mechanical total counter defective
• BICU defective
• Disconnected mechanical total counter
Ricoh Aficio... | Answered on Mar 31, 2015
With a 1440 watt and 12 volt, the battery must be over a thousand AH. (ampere/ hour) because for the 1440 watt, you need a current of more than 100 ampere. But even with a few hundreds of watt, you need a very powerful battery, because 300 watt, will pull 30 amps from the battery. A car battery with even 100 AH can't deliver that.
Ricoh Aficio... | Answered on Mar 23, 2015
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Ricoh Aficio... | Answered on Feb 24, 2015
copier doesn't have this feature. mp 161 has it called rx mode auto switch time
Ricoh Aficio... | Answered on Oct 10, 2014
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
Ricoh Aficio... | Answered on Sep 02, 2014
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
Ricoh Aficio... | Answered on May 26, 2014
Ricoh Aficio 2018D All-In-One Laser Printer Logo
145 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error sc553
  • Office Equipment & Supplies
