20 Most Recent
Ricoh Aficio 1018D All-In-One Laser Printer Questions & Answers
Error sc 194
samply clean exposure glase and mirrors carfuly
Grinding noise
Could be photoconductor gears are bad will have to replace unit or fuser unit you will have to decide which one first
Grinding noise
Remove all paper from unit and carefully check in corners for a paper jam or staple/Paper clip
Ricoh 1018 copierscan light not coming on and
194
B SBU White Level Detection Error
The automatic SBU adjustment failed
twenty times consecutively.
• Exposure lamp defective
• Dirty white plate
• Incorrect position or width of white
plate scanning (☛ SP4-015)
• BiCU board defective
• SBU board defective
Problem with the scanner. Check the white registration strip. and clean the mirrors. normally works.
Reset my password for Gestetner dsc 460
Try admin and leave password blank if that doesn't work then log on to web monitor . Open your web browser ie or Firefox doesn't matter enter IP address in browser then log in as supervisor no password and change name and password
Error sc543
replace the thermistor and thermostatic some time maye be power supply
Network printing
If you can see it, it is set up right, however, the configuration might be wrong. Go to printer properties in the control panel. Open up the ports tab, select configure port. You will see that it is probably set: protocol:Raw, port:9100. Sometimes the port is 10001. Otherwise, set it to LPR, and put LP1 for the queue Name. That should do it.
