20 Most Recent
Ricoh Aficio 1018 Printer Questions & Answers
Error sc320 how to reset this problem please
SC320 IS A LASER PROBLEM .
KINDLY AND CEREFULLY REMOVE THE LASER UNIT AND WASH WITH DETERGENT VERY THOUROUGHLY AND DRY UNDER THE SUN FOR ABOUT THREE HOURS AND REPLACE IT BACK TO ITS POSITION .
IF U POWER THE MACHINE AND THE SAME PROBLEM OCCURS, CHANGE THE LASER COPLETELY.
GOODLUCK.
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Error code sc500
Your main motor is hard to turn.. Check your Drum unit. Pull it out then on the back side you'll find a small agitator gear then tried to turn it. If it doesn't rotate then you might have to change its paddle gears, idle gear or that development sleeve is stuck. Hope it helps.
Sc 500
check ur developing section whre the developer install, ur gear is brocken
Ricoh mp c3000 colored copies are double print
Could be drum units there are 4 drums or fuser assy. since you said color only I said drum unit try scanning a single color see which one does it . Will need to call a copier company or go online and buy a whole photoconductor . You will need to know how to initialize unit before you put it in.
Sc500
"Main motor lock" Check the drum/dev unit that can cause this error code.
