20 Most Recent
Ricoh Aficio 3800CMF Laser Printer Questions & Answers
Ricoh 3800c call for service
On the screen where it says "Call for service," there should be an error code (starting with "SC" and ending with a 3-digit number). This code can tell you what is wrong with your machine -- what code is displayed?
Does turning the machine off (with the main, orange power switch) and then back on clear the error message?
Codigo sc 552 ricoh 3800
SC 552 - Pressure roller warm-up error
Definition: After the main switch is turned
on or the door is closed, the
pressure roller temperature
does not reach the ready
temperature within 150
seconds during fusing unit
warm-up.
Possible Cause:
• Pressure roller fusing lamp broken
• Defective pressure roller thermistor
• Defective BCU
Troubleshooting Procedure:
1. Check if the pressure roller thermistor
is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
Ricoh Aficio Aap 3800c
I replaced
Hi aftab98,
Welcome to Fixya. It would seem that the "paper jam error" is common with this model. Apparently, the roller pin on the fuser unit is the culprit. The roller pin could be loose or even dislodged.
Could check if you could separate the fuser oil unit from the fuser unit? Both ends has roller pin that has to fit just right with no wobble, looseness or misalignment. You can use this manual and might help you in the removal refer to page 7
Thanks for using Fixya.
I have a Gestetner DSc38u
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
I need to change the transport belt on a Lanier
There is no way to describe this in an email. Just disassemble starting from the front cover of the trans asm. Check the old belt when you take it off, one side of the belt has an encoder strip built into it.
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Error code SC551
Hi SimonCC,
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
You may check various websites for thermistors like ebay, spareparts etc......
Ricoh 3800c sc285 error message
Most of the time it is the transfer belt. The belt has gotten scratched up with age and the mach has trouble doing the line position adj.
Printer with parallel port not "seen" on my Mac
I've never had much luch running parallel printers on UNIX systems, it seems that a serial connection works without any trouble.
At any rate, have you tried hooking it up to a stationary windows machine, and then sharing it using windows networking.
Then, you could simply print to it by using SMB...
I've done this before and it seems to work fine.
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
