20 Most Recent
Ricoh Aficio IS420 Flatbed Scanner Questions & Answers
Ricoh Aficio 1027 stopped working
You were able to scan okay before? If you can print but not scan, generally it's a firewall or permission problem. You could try creating an exception for the Ricoh in your firewall software.
The folder that you scan to hasn't moved, has it? Is the path still exactly the same? Try turning off your firewall and/or anti-virus software and see if you can scan then.
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Dark area on scanner output
you need a new CIS array, or the lamp is going bad. With all due respect buying office equipment on ebay is like shooting craps.
http://www.websitetoolbox.com/mb/copierquestions
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
