20 Most Recent Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Questions & Answers
This is a hardware failure on the screen. The screen will need to be replaced. It is probably cheaper to get a new tablet.
Samsung Galaxy... | Answered on Mar 20, 2019
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
Samsung Galaxy... | Answered on Nov 30, 2016
found this
https://productforums.google.com/forum/#!topic/play/xPUdySfE3IY
Samsung Galaxy... | Answered on Aug 16, 2016
Have you tried recalibrating? There is an Android utility for that under the system icon.
Unless you have a location app installed you can't
Samsung Galaxy... | Answered on May 31, 2016
Verify that your router has a good internet connection and that its local IP service (usually through DHCP) is running. Try entering the router's TCP/IP address (e. g., http://169.168.1.1) in your browser's address bar to see if you can get the router's status page.
One of the more common failures in older routers is IP service dropout, particularly if the router overheats because something was stacked on top of it. This will result in client error messages such as the one you describe.
Another possibility is an authentication failure, but that would generally mean somebody messed with the wireless network access password, or there's a bug in the wireless coding (as in some ASUS laptops - this was fixed in a firmware update).
Samsung Galaxy... | Answered on May 28, 2016
Click the account menu at the top right of any Facebook page.
Select Settings.
Click Security in the left column.
Choose Deactivate your account then follow the steps to confirm.
Samsung Galaxy... | Answered on Feb 07, 2016
your WI FI password should be on the back of your ROUTER . try typing in your Browser search box Make, model also state its a Wi Fi tablet click on search and on the page that appears . If you have a PC or Laptop use it to get the manual then you can read the instructions while setting up your tablet . Hope this helps .
Samsung Galaxy... | Answered on Jan 20, 2016
Install antivirus an remove virus or reset phone to hardware original setup!
Samsung Galaxy... | Answered on Dec 24, 2015
You can put it in airplane mode, and out of it again. That should solve it, but it will come back when you restart the device. Some people experience it due to the NFC function being on. Try turning that off as well. Hope this helped
Samsung Galaxy... | Answered on Dec 15, 2015
lower the resolution settings
Samsung Galaxy... | Answered on Nov 25, 2015
Go in to settings accounts and delete the account
Samsung Galaxy... | Answered on Oct 02, 2015
Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Logo
139 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Tablets & eReaders
Most Popular Question
error message battery will explode
  • Tablets & eReaders
