20 Most Recent
Samsung GT-P7500 Galaxy Tab 10.1 UNLOCKED QUAD BAND Wi-Fi and 3G 16 GB Tablet Questions & Answers
Unlock codes tablets
the best way to do this is to get a unlocking subsidy pin.on the back of the device there should be a network operator who the phone/tab is branded to. you will need to contact them direct and put in a request.this code usually cost about 20.00 but once you have the code it will unlock your device forever and its the safest way to unlock it rather then go to the market where they may damage the software that is installed on the device.
Samsung M9701 TW
What exactly is the issue you are facing. I only see Model numbers posted in your title and description.
My ivso bluetooth keyboard does not hold its charge. What could be the issue and how do I fix it?
- Battery issue: The battery in the keyboard may be faulty or have a low capacity, which can cause it to quickly drain and not hold a charge.
- Charging issue: The charging port or cable may be damaged, preventing the battery from charging properly.
- Keyboard software issue: There may be a software issue with the keyboard that's preventing it from charging correctly or retaining a charge.
- Connectivity issue: The keyboard may not be compatible with your Samsung tablet, or there may be a Bluetooth connectivity issue that's causing the battery to drain quickly.
It is recommended to have the issue diagnosed by a qualified technician or customer support for the keyboard manufacturer. They can diagnose the issue and provide a solution to resolve the problem. Ignoring the issue could lead to further damage and increased repair costs in the future.
