20 Most Recent Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet Questions & Answers
please follow that video and use which method more convenient to you.
https://www.youtube.com/watch?v=BCYUMoVpyiY
Samsung Galaxy... | Answered on Sep 22, 2017
if the battery will not charge there are possible explanations
that you recharge the battery before it is run completely down and now it has a memory level that it will not charge past
the light or camera is being used excessively
the unit is left switched on when not in use
trry replacing the battery with a new one
Samsung Galaxy... | Answered on Feb 11, 2015
search the top and side corners use a pin to open the sim port like now a days smartphone
Samsung Tablets... | Answered on Dec 02, 2019
Hi remove battery wait a short time before u replace it
then press & hold the power, home & volume buttons at the same time. Release buttons when Samsung logo appears
recovery option should come up on screen ........cheers
Samsung Tablets... | Answered on Nov 26, 2019
You can do a Hard Reset, but if it is stolen, the phone is locked at hardware level and can only be unlocked by the telco that owns the phone.
Press and hold Volume up, Home and Power buttons until the Samsung logo appears on the screen. Press the Power button. Press the Power button. The tablet will now wipe all contents.
How to perform a hard reset when my Samsung Galaxy Tab A ...
https://support.bell.ca > mobility > smartphones_and_mobile_internet > sams...
Samsung Tablets... | Answered on Nov 21, 2019
I'm not sure either, and I'm almost sure you heard about Odin. Odin is a pc program that allow Samsung devices to flash stock firmware or unofficial ROM. Search for "How to use Odin".
Samsung Tablets... | Answered on Nov 11, 2019
App drawer > Settings > Connections > Hotspot & Tethering
Note that some carriers disable hotspot, but you can still tether with a third party tethering app like Barnacle.
Samsung Tablets... | Answered on Nov 06, 2019
I am sorry for your loss, Depends if you want to save the data or not.
If not, then you should be able to do a factory reset. Google for Factory Reset Samsung {your model}
https://www.technipages.com/galaxy-tab-4-hard-reset
Otherwise,
Unfortunately, nobody here can tell you how to crack your sister's passwords. You can contact Google and jump through their hoops to provide the necessary documentation (***** certificate, proof if ID etc,) but it won't be easy,
Samsung Tablets... | Answered on Nov 03, 2019
Connect Samsung to laptop via USB cable. Laptop should mount the Samsung as one of your hard drives. You can then drag and drop files back and forth between the two.
Samsung Tablets... | Answered on Oct 25, 2019
You can unlock a device remotely if you have it registered to a Samsung account. On another device, go to findmymobile.samsung.com and log into your account. (I was able to reset my Samsung account password using the link before proceeding.) On the next screen, click Find, then More, then Unlock My Device. I had to reset all passwords, PIN, etc for the tablet, but so far it looks like all my downloads and other personal data is intact. Hope this helps!
Samsung Tablets... | Answered on Oct 15, 2019
That does not sound right. I have had several Samsung tablets and never saw that. If the tablet it new it sounds like it might be defective.
Samsung Tablets... | Answered on Sep 29, 2019
Go to google play on your tablet and search the app you are looking for.
Samsung Tablets... | Answered on Sep 18, 2019
The only option is to reset your unit if you forgot the password of your tab. Follow the step by step tuturial
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  3. When the Samsung Galaxy Tab E logo screen displays, release only the Power key
  4. When the Android logo displays, release all keys ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  5. Press the Volume Down key several times key to highlight 'wipe data / factory reset.'
  6. Press Power button to select.
  7. Press the Volume down key until 'Yes -- delete all user data' is highlighted.
  8. Press Power button to select and start the master reset.
  9. When the master reset is complete, 'Reboot system now' is highlighted.
  10. Press the Power key to restart the device.
Uninstall the third part apps that can cause an advertisement when you connect to internet.
since their different OS, we have to get help from some third transfer applications to figure out how to transfer photos from samsung galaxy to ipad How to Transfer Photos from Samsung Galaxy to iPad Easily
Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet Logo
15 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Tablets & eReaders
Most Popular Question
transfer vidoes photos from samsung 7 7
  • Tablets & eReaders
