20 Most Recent QPS Que! CD-Rewriter CD-RW Burner Questions & Answers
Yes. Many burning apps (such as Nero) support the creation of Video-CDs, and most current DVD players support playing these Video-CDs.
QPS Que!... | Answered on Oct 09, 2019
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
QPS Que!... | Answered on Dec 13, 2010
Buy a DC adapter from your local electronics shop.
QPS Que!... | Answered on Jul 07, 2010
qps que model 525 will not start. used to work on xp and vista. I think disk is getting full - down to 4 gb left... but problem remains that I cannot start it or open it. Can anyone help?
Thanks.
QPS Que!... | Answered on Dec 29, 2009
Windows XP has "built-in" software for writing CD-R disks.
Or, download the FREE "Ashampoo Burning" CD-writer software from http://www.MajorGeeks.com
Version 6 is "free", and Version 9 (which is *NOT* free) is good software.
QPS Que!... | Answered on Oct 26, 2009
i prefer u to use windows 7 ,it cheap and convienience in burning and any kind of disk without a programme(like nero) to do that and it have usb mobe for cd or dvdr mean it use your cd/dvd r like a usb (read,delete file even it a cd-r not a cd-rw)just simply double click in your drive and it will ask u to do that
QPS Que!... | Answered on Sep 23, 2009
oh did u need a driver to do that ,u must type yer cd version and google it then open control panel -device manager- choose cd device ,right click choose <update driver software> u can choose update thought yer network or u can browse it to yer dirver downloaded
what kind of yer blank disc ,it must be dvd-r 16x or dvd-rw recordable
try to insert disk when it in dos mode then normally log in windows
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
QPS Que!... | Answered on Sep 15, 2009
how do you make a HD into a CD I am not reading this right.
all you can do is videos that are digitized and audio files and play them back as such using media player no conversion involved
QPS Que!... | Answered on Jul 31, 2009
Lol,don't worry i had the same thing,first make sure when you are writing a dvd you have changed the setting on nero to dvd,the progress bar at the bottom will change from 700megs to 4.7gigs... and its also depends wether you are writing 4,7 gigs or 8.4 gigs...try it out.
QPS Que!... | Answered on Jul 23, 2009
get an external dvd burner,it connects via an usb cable
If its on xp and on an ide its should do it automatically. maybe change your jumper settings to cable select and make sure it has power
A paperclip should eject the tray, what happens when you use the paperclip? Have you been able to successfully use a paperclip in the past on this exact drive?
QPS Que!... | Answered on Jun 26, 2009
Try reinstalling the drivers for your CD bay.
Either the CD that came with the bay, or find them online ....
Right-Clickie your My Computer and find the name of your CD Bay in the list on the Hardware page ... delete it, or right-clickie and uninstall the driver.
Reboot the computer and it should re-detect the drive, or find the drivers you copied earlier.
If that doesn't solve the problem, then it might be the type of CDs that you are using. Have you changed brands lately??
QPS Que!... | Answered on Jun 13, 2009
The lens could be dirty. I would try cleaning the lens of the drive.
here's a video on the cleaning I found from youtube, its annoyingly loud but shows how to clean the lens with rubbing alcohol.
may want to turn the volume down in advance:
its for a ps2 but the drive is basically the same, and you would clean the lens in the same way.
you will have to open the burner up to do the cleaning, the drive has 4 screws in the bottom, you will have to eject the tray of the drive so that it opens a little, theres a small hole on the front, then you will have to eject the clips on the front cover and the drive comes apart.
then you can do the cleaning, make sure you get all the dust out while your at it.
let me know how that goes.
Thanks,
Ekse
QPS Que!... | Answered on Jun 04, 2009
wont burn cds
QPS Que!... | Answered on Mar 19, 2009
QPS Que! CD-Rewriter CD-RW Burner Logo
32 questions posted
Top QPS Computers & Internet Experts
Jean Thiebaux
B.Th. Pluijm
B.Th. Pluijm
k24674
Are you a QPS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • QPS Computers & Internet
Most Popular Question
pioneer dvd rw dvr 106d
  • Computers & Internet
