20 Most Recent QPS Que! Fire CD-RW Burner Questions & Answers
Well you just take a small flat head screwdriver and the side grips and the faceplate just pop right off. Then you get the hooks to release on the inside of the main body by sticking the screwdriver in and popping the hooks.
QPS Que! Fire... | Answered on Mar 30, 2011
you might have to physically unplug the leads for this cd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps dont forget to vote
QPS Que! Fire... | Answered on Mar 13, 2011
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
QPS Que! Fire... | Answered on Apr 25, 2010
hey i have 2 of the drives but no powercord or supply i was wondering how does it look could i get pics
QPS Que! Fire... | Answered on Mar 30, 2010
You need to use a disk made for Lightscribe. Lightscribe technology was developed by HP.
Look at your local store that handles CD's, and DVD's, and look for the Lightscribe disks.
More information about Lightscribe,
http://en.wikipedia.org/wiki/Lightscribe
QPS Que! Fire... | Answered on Oct 22, 2009
You state that you have installed a new power supply. Check whether you have all the cables securely. One is a power cable and the other is a flat SCSI cable connecting your DVD drive to the motherboard.
QPS Que! Fire... | Answered on Sep 19, 2009
I devised these simple steps that tend to remedy quite a few common USB problems.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability.
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you suspect a cable NEVER get one longer than the one you want to replace
If you checked and fixed anything there and still have issues it may well be due to the device itself or a weakened usb port, a loose usb port.
To remedy the last two consider a new usb card if it for a PC
QPS Que! Fire... | Answered on Aug 24, 2009
I am needing to reinstall my external Ativa drive, but cannot find the installation cd anywhere!!! HELP!
QPS Que! Fire... | Answered on Jul 22, 2009
Hi Mil,
The connector on this drive is a firewire connector. They originated on Mac Computers, although some PC's have them they are not standard. You will either need to exchange this drive for a USB model or take your PC to your local shop and ask them to add a 1394 or forewire card to the computer in order to use the drive.
Also be sure to take the drive and cable with you as there are 2 standard sizes and you want to make sure the card they install is the right one, or has both.
Hope this helps FixYa,
Chris
QPS Que! Fire... | Answered on Jul 18, 2009
try using a burning program wothy of the attempt.real player works off a basic set of drivers and fails on many occasions. if your burning from dvd to dvd use dvdfab version 5.0 or higher. this will right past any copyrights. or if burning from files use nero version 7.0 or higher. anything less is a waist of time.
QPS Que! Fire... | Answered on Jul 09, 2009
go to lighstrcribe.com and dowload all the software there.
there are special programs/drivers there that you need to have.
then reboot and nero should pick it up
QPS Que! Fire... | Answered on Jun 23, 2009
the driver is packaged with nero 7 essentials (Grrr...)
QPS Que! Fire... | Answered on Apr 14, 2009
Use Internet Explorer to download this file:
http://winhlp.com/tools/resetdma.vbs
Run it.
Reboot system.
QPS Que! Fire... | Answered on Mar 19, 2009
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-clickon Lightscribe Service, and if it says disabled change it to automatic,then "start service" in the left pane if is already started and set toautomatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
QPS Que! Fire... | Answered on Jan 19, 2009
hello sir..i have a solution to your CD burning problem...sometimes if you are not regularly using your CD-RW drive then there are chances of CD-RW lense prob,so please do clean the lense using lense cleaner CD available in the market,even then if you not able to burb the CD then please do reinstall the software which you are using for CD burning...i suggest you NERO software for CD burning which is a user friendly software...
QPS Que! Fire... | Answered on Oct 30, 2008
may be u r cable is out
1st check u r cables...
if it dont work pls contact ur computer dealer emidately...
or replace u r drive if it is in warrenty....
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
QPS Que! Fire... | Answered on Jun 12, 2008
download free nero software
will it select what you want the disc to be
DVD or CD
QPS Computers &... | Answered on May 01, 2017
QPS Que! Fire CD-RW Burner Logo
Popular Tags
31 questions posted
Top QPS Computers & Internet Experts
Jean Thiebaux
B.Th. Pluijm
B.Th. Pluijm
k24674
Are you a QPS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • QPS Computers & Internet
Most Popular Question
computer not recognize
  • Computers & Internet
