20 Most Recent Samsung Pn64d8000 64-inch 1080p 600hz 3d Plasma 8000 Series Smart Tv Questions & Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Samsung... | Answered on May 09, 2017
As you yourself have stated, this is a TV. Perhaps a post in a consumer electronics forum might be in order, to find someone with expertise in such items.
Samsung... | Answered on Feb 21, 2017
Probably the failing power supply finally failed completely.
Samsung... | Answered on Mar 07, 2016
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Samsung... | Answered on Nov 16, 2015
Anyone answer this? This is really annoying!
Samsung... | Answered on Jul 27, 2014
Refer to the users manual page 130. The eco solutions control many of the power off features.
Another possiblity is the TV is overheating shuting down to protect itself. Check for blocked vents in the rear.
In the user manual on page 66 there is a setting for internal/external speakers. Set the TV to external speakers which will turn off the TV audio.
To be able for you to play mp4 videos on your camera, you have to make sure that you have converted the videos to a format acceptable to your device. Formats like , vlc, avi etc. then you also need to check the size of the video as well.
Hope this helps
Thanks
Dennis
Samsung Cameras | Answered Yesterday
Some of the Samsung models do have service bullitins regarding a change in the mounting and size of the LCD. Contact Samsung customer service and let them know what has happened and they will help you.
Samsung Cameras | Answered on Dec 02, 2019
There is probably a port underneath, with a screw-cap for protection, which you can open to let out the used electrons.
Samsung Cameras | Answered on Dec 01, 2019
Check out this WEB site for camera USB cables.
You may also need a charge adapter to charge the camera battery.
http://ubercable.com.au/index.php/camera-camcorder-digital-camera-camcorder-usb-c-33_104?gclid=COTV7cmfwbICFeJMpgodACEAYg
Check out EBay for a charge adapter.
http://www.ebay.co.uk/sch/i.html?_nkw=samsung+wb+720
Samsung Cameras | Answered on Nov 27, 2019
install the latest firmware by downloading T-valdeuc-3009.2 from the samsung support page. I have been waiting for this fix for 6 weeks. I tested it this evening and it works. Unfortunately i think you will only get sd and not hd, but better than nothing
Samsung Cameras | Answered on Nov 21, 2019
Hi - You can download the manual by clicking the link underlined in blue below:
samsung S850
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Samsung Cameras | Answered on Oct 29, 2019
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site;;: http://Geosalary.com
Samsung Cameras | Answered on Oct 24, 2019
Can you explain what you mean in more detail, please ?
Samsung Cameras | Answered on Oct 10, 2019
Samsung Pn64d8000 64-inch 1080p 600hz 3d Plasma 8000 Series Smart Tv Logo
15 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
pn64d8000 samsung no picture not power
  • Cameras
