20 Most Recent
PSC QS6000 Plus Handheld Questions & Answers
Volume for barcode
Dear Jndow,
By using programming manual you can control volume of speaker in side the scanner.
Deepak
I have a Dell Optiplex
Most probably you have only one slot of RAM (a 256MB) if so you will need to upgrade it to more such as 1GB of RAM, the problem seems to be that the OS needs more Random Access Memory to connect with your Scanners drivers and make them part of the system such that you can be able to use it when you log in this becomes a problem as with limited Memory the OS fails to read the drivers and linking the scanner gets interrupted thus hanging on startup as it has other processes using the RAM at the same time and thus sharing it with the Scanner drivers and configurations. After other programs and processes have finished to run and minimal background processes are left after logon then this means more RAM is available so the Scanner can work easily when plugged at this point.
