20 Most Recent Nikon SB-700 AF Flashlight Questions & Answers
Your camera should be capable to record video for 30 minutes in a row. The SD card should be more than 4Gb to record 30 minutes. and not 128 Mb.
I think you have a 128 Gb card, if not the card is the problem. 128 mb is really not enough for 30 minutes. It would be just enough for one and a half minute.
Nikon Cameras | Answered on Jan 12, 2020
there may be shot circuit in the flash drive circuit, open camera and test the related components especially diodes,capacitors, choke etc, be careful when you handle the flash section severe shock will get so please discharge the 400 volt capacitor.
Nikon Cameras | Answered on Jan 08, 2020
please re set the camera in the menu
This camera was introduced 16 years ago. Maybe time to think about a replacement ?
Nikon Cameras | Answered on Jan 05, 2020
Yes they do!
Is that a question?
SD Card doesn't work in the camera? You have to Format it inside the camera. The camera uses a custom storage format.
Or do you want to buy one.
Or do you have a card and want to load the images to a computer?
so many questions!!
Nikon Cameras | Answered on Dec 26, 2019
Professional service ONLY.
Nikon Service and Repair
https://www.nikonusa.com > service-and-support > service-and-repair
Need assistance? Call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday. ‎Nikon Authorized Repair ... · ‎ApprovalLogin · ‎Product Entry · ‎Dealer Login
Foreign body of some kind (grit, sand, hair etc) has entered the lens extension / retraction gearing. Probably not worth cost of repair.
Nikon Cameras | Answered on Dec 02, 2019
Refurbishing is a nebulous term that can describe everything from cosmetic touch-up to full operational checkout. You may have to have your Nikon unit returned for the latter.
Nikon Cameras | Answered on Dec 01, 2019
C? b?p c?a b?n, c?a ch?ng t?i, m?t ph?n c?a ch?ng t?i khi b?n s? d?ng m?t c?ch an to?n. C?u Tin s? l?m ??p, m? b? xem t? m?ng: https://phunusacdep.org/
Nikon Cameras | Answered on Nov 19, 2019
In most cases you can DOWNLOAD a manual when you go to Nikonusa dot com. Search for EXACT model of camera and DOWNLOAD the Manual. It is in PDF form.
I like PDF manuals because you can SEARCH for items you need help on fast.
Nikon Cameras | Answered on Nov 07, 2019
GPS does not work everywhere. You need clear, unobstructed view of sky. Indoors heavily wooded areas can render GPS useless.
Tool (Wrench) menu World Time or Time & Date Menu.
Nikon Cameras | Answered on Nov 06, 2019
Whatever button you used to select the ‘date stamp’ option, on most digital cameras, it’s usually a second button to ‘select’ whether you want it on or off.
Nikon Cameras | Answered on Oct 22, 2019
I had an issue where the camera would not turn on and if it did, then it would be rarely at all. I attempted to replace the batteries, removing memory card, cleaning for sand and dust, and practically everything that has been recommended online. I was able to fix the issue by holding the preview pictures button (I don’t know the actual name of it but it looks like a rectangle with a play button in the middle) which turned the camera on to view the pictures. Then, I went into menu > clicked over to go to settings > and went down until I found “reset all.” Afterwards, I tapped the button that takes the picture and all the sudden it was good as new. It will turn on and off as it did before the issue arose. I don’t know if I just got lucky or this will work for others, but I wanted to share.
Nikon Cameras | Answered on Oct 21, 2019
If this is possible, which I doubt, instructions will be found in the manual which accompanied the camera upon purchase.
Nikon Cameras | Answered on Oct 19, 2019
Nikon SB-700 AF Flashlight Logo
2 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
brand new out box installed brand new
  • Cameras
