20 Most Recent
Rokinon 3000e Camera Questions & Answers
What kind of film does a rokinon 3000e take
It uses standard 35mm film. You can probably find color print film at most drugstores and supermarkets. You'll also find black-and-white and color slide film at any good camera store.
TRYING TO CONNECT
Fixya does not provide any kind of internet connectivity - methinks thou mayst have directed thy query to the wrong site.
Rokinon D=70mm F=500mm user manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Roku2 universal code
From Internet, check it whether it works for you.
52371 and 53061 are the two codes listed for Roku for the RCRN04GR remote. The 53061 code worked with full functionality for my Roku 3.
How do you get out of Roku back to regular tv?
Change the Input on the TV. Like from HDMI 1 to HDMI 2 for example. Or to component video. Trace the wire from your cable /satellite receiver and see where it's plugged into the TV then select that input.
Why doesn't my rokinon 500mm lens work with my Nikn D3100 camera?
The lens does not have the electronics to communicate with the camera. It will work fine in Manual exposure mode. Turn the mode dial to M. You'll have to set the shutter speed yourself, without any help from the camera's exposure meter. You'll also have to focus yourself, of course.
Setting nikon d90
Turn the mode dial to "M". You control the shutter speed by turning the command dial, and you control the aperture by turning the aperture ring on the lens. The camera's exposure meter is shut off and won't help with the exposure. You can shoot a picture and look at it on the display to judge the exposure.
Error messages nikon d7000
Nikon makes several different 85mm f/1.4 lenses, but it appears you're using one with an aperture ring. Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring.
My camera wont turn on
Probably needs a premium battery like a duracell. Some of the cheaper batteries just wont power the camera.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
