20 Most Recent
NEC SuperScript 860 Laser Printer Questions & Answers
Cat de performanta este
Black Print Speed:
8 ppm (viteza printare negru)
Total Media Capacity:
200 Sheets (capacitate totala)
Max Resolution (BW):
1200 x 600 dpi --\>Rezolutie maxima
How do I create a
DEGREE AND OTHER SYMBOLS ARE LOCATED IN OFFICE SOFTWARE LIKE MS WORDS. IN WORDS YOU MAY PRESS "INSERT" THEN "SYMBOLS
" THEN CHOOSE YOUR SYMBOL THEN ENTER
Nec superscript 860 printer driver
Hi Richard,
As you might all ready know, this printer is not supported by Vista,
pasible solution: - if you have another "old" computer, you could install your printer on that, and share it, that way you can printe via the other computer.
in case you want drivers for all other software,
here is the link.
regards
/Teis
Superscript 860
If you can reach the sheet, you may apply a lot of force on in without the risk of destroying the printer.
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Nec superscripct860
I bought a new compaq computer and I need the software to install the superscript 860 lazer printer.
Problem in feeding papers
Sounds like the pick up rollers are either dirty or are worn out. You can try cleaning them with a soft lint free cloth. Just look for a roller or wheel looking item where the printer picks up the paper. If they feel very smooth then they maybe worn out and may be replaceable. Check the owner's manual or the manufacturer's website to find out.
Hope this helps!
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
